Hi i purchsed a 3545 spool gun and 100c control box on Ebay to use on my 1975 miller big 40. I recently got around to hooking it up and trying the setup out. My problem is the arc is very difficult to almost impossible to get started especally at lower amps. Any help would be greatly appreciated.
Miller 3545 spool gun hard arc starting
Originally posted by cruizer View PostWell of course your going to have a hech of a time, as your big 40 is a CC only machine whilst your wire, and thats any wire kinda needs CV
Read here. http://www.weldmart.com/aec-200%20cc...n%20system.htmLast edited by aametalmaster; 08-21-2011, 12:46 PM.Bob Wright
Nope on the 3035 coupling to a WC115, and unless your running steel, on a voltage sensing feeder, not much is going to work for you.
I mean mild steel wire on CC is going to be non structural spray, dual shield works great but I don't think you can get 2lb spools.
Aluminum works ok, once you get it started, but you'd likely go through multiple tips and wire before that happened.
Innershield is so, so, on CC.
Now the reason behind the voltage sensing aspect on CC, is that its virtually impossible to control your wire stickout, thus burning back to the tip is a contant problem. As your varing a limited voltage with your wire speed overcomming the already high fluctuating amperage
In CV, your controlling a set limited voltage and adjusting amperage so wire stickout is not a problem
