I have a Diversion 180 that I bought new a few months ago and have finally fired it up and tried to tig some aluminum. The aluminum I am working with is 16/18 gauge so it is thing. I am repairing automotive body panels so there is some pitting in the aluminum. These have been stripped and blasted so they are clean. What I am having issues with is the arc. The arc is "dancing" all over the place. I followed Miller's recommendation for preparing the tungsten. Made a point then landed the tip. I think I did that part right. Any suggestions on why this is happening. I searched the forums and really didn't come up with an answer. Oh, it worked great for doing steal. Thanks.
Aluminum Tig Question
Welcome.
Here are a couple suggestions:
Make sure with that thin material, you are using a 1/16 tungsten, collet and collet body.
Also your filler shouldn't be thicker than the material you are trying to weld.
If the material was blasted, make sure it's properly cleaned after. Tig welding on fresh blasted Aluminum usually results in unsatisfactory results and contamination from the blast media.
Turn the main amperage of the machine down to less than 90 amps. This will give you more foot control resolution.
Good luck.
Andy
I am using the 3/16 tungsten that came with the welder; red one, I know it's not pure tungsten. I can pick up those. I am using 1/16 filler also. They way I am grinding the tungsten, is that correct way for aluminum tig with this machine.
Thanks for the reply.
If you are using a 2% tungsten and your machine has a negative polarity, try this. Grind the tungsten to a point. switch to neg polarity. Arc it just for a second or two and you will see it form into a ball. that's what you need for aluminum. Then switch the machine back over. Other than that get 100% tun. I don't grind mine to a point as the abll will form on 100% naturally.
Originally posted by OlSkool View PostI think I will pick up a 1/16 tungsten & collet and see what happens. I will also talk with the weld store and ask them and see what they have to say.miller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####d
OlSkool,
Just a tip.
Disregard all the other BS from uninformed posters and listen to what Andy told you to try.
As Andy mentioned, blasting the aluminum is not "satisfactory prep". Use a SS brush and clean it throughly. If there's dust left behind, clean it with a clean rag and acetone or alcohol. Aluminum must be CLEAN to tig weld.
Keep your arc length short, about the length of the thickness of your tungsten.Syncrowave 250 DX Tigrunner
Dynasty 200 DX
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Once your surface is clean and you have purchased your 1/16" torch parts, grind to a sharp point like a pencil profile and LEAVE IT!
Do not ball back, and do not grind a land on it. It will erode on it's own, it does not need any help from you.
Good luck and report back.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
With that type of flat repair, having your tungsten stick out 1/4-3/8 is common.
Don't run GREEN tungsten in this machine.
Keep your arc length tight but not touching the base metal. The higher your arc length, the more power the machine has to put out and therefore heating up the base metal too much and could burn through.
You could also use a copper backing plate behind the repair area to help with burn through proplems.
Andy
Originally posted by jay2001 View PostIf you are using a 2% tungsten and your machine has a negative polarity, try this. Grind the tungsten to a point. switch to neg polarity. Arc it just for a second or two and you will see it form into a ball. that's what you need for aluminum. Then switch the machine back over. Other than that get 100% tun. I don't grind mine to a point as the abll will form on 100% naturally.
I believe these machines all come with 2% Ceriated (orange tip). That's the one you want to start with. Period.
I'm assuming "askAndy" is Andy Weyenberg. I could be wrong...
As for advice. Not only does Andy know what he is talking about, he is a decent enough teacher - at least as much as you can get from a video.
http://www.millerwelds.com/resources/video_library/
It would be crazy not to at least watch the videos on aluminum TIG at least once before you attempted it yourself. Watch 'em in order. There are lots of good hints in there that you will not find anywhere else.Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Hypertherm PowerMax 1000G3
Ok- here goes
First- since you are doing aluminum, and its a thin guage, go to your friendly neighborhood welding supply, and-
1) Ask for a 2% lanthanated tungsten preferably 1/16", and grab a collet to match, and the next two sizes larger cups, than you have now. 2) Grind your tungsten to a nice textbook point, just like your book tells you to.
3) Clean that aluminum METICULOUSLY with acetone, or some other suitable solvent, and for goodness sakes, make sure its dry, and you have properly isolated all the solvents and cleaning materials from your general vicinity.
4) Now that its been cleaned, mechanically clean the weld area with a DEDICATED stainless steel wire brush (for aluminum ONLY)
5) Set your welder at about 90 amps, install the next larger size cup (helps to make a larger area of shielding gas, and helps you keep your filler material clean as you weld) use the pedal (finer control than on the torch) and get to weldin'.
Let us know how you make out, I hope this helps you get where you want to go
Lucky
Thanks for the help. I have to pick up supplies this week and then I will try it. I hope to try it this week and post an update. I will try. Thanks again everyone for all the great advice. It has been 5 year since I tig welded aluminum and that was with a big old Miller machine and that welded nice. I am not used to the Diversion yet so that is part of my issue. I could do steel just great with it so I knew I was doing something wrong with the aluminum. I will get the smaller tungsten and do a better job at cleaning. I have a few days worth of fixing these aluminum shrouds so I want to do it right. Will post an update when I get to welding.
