I am a welder with 20 years behind me and just had my physical today for a civilian welder in Norfolf Naval Shipyard. I learned that I have to train to be a nuclear welder once I start work in Sept. What is involved with that process? What type of classes are they going to give me and things of that sort. Also am I more likely to travel with Nuclear Certs? Thanks.
Nuclear welder in Norfolk VA
A few years ago the company i worked for was trying to get into welding nuclear tanks. There is alot involved. I imagine your going to learn about the procedures and the paper work. Procedures have to be followed to a t, and also the paper work must be filled out accuratly. Such as material temp while welding, heat numbers from your wire along with witness's to verify temps and such. There is alot involved. Like said much like asme pipe code. This is just what i learned from working in company trying to get into it. But best of luck it certainly is high end workLinclon power mig 350MP
sorry to say i don't know jack about nuke welding. if my brother was still around he could tell you all about the navy way of nuke welding. he retired out as chief in charge of the sheet metal and pipe shops aboard the USS Enterprise. he had about every cert known to the navy including nuke subs. i have known many welders but that guy was the master in anything to do with fire and metal. sorry to say i didn't learn enough from him because like most brothers if we weren't having a good time together we were fighting like cats and dogs. but like he always said when it has to be done, "there is a right way a wrong way and THE NAVY WAY". like said already, 50+ years of nuke Navy way can't be the wrong way.....good luck.miller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####d
Originally posted by bretsk2500 View PostThey (the USN) will teach you "The Navy Way".... a way which has had zero nuclear incidents since the USS Nautilus was launched...
Wheelchair
Originally posted by Wheelchair View PostThis is the right answer. You can throw out any certs that you have as you will be re-taught not only in welding but also in a score of rad-con procedures and everything you do will be monitered.Bobcat 225NT
Cutmaster 52
Lincoln Weld-Pak 100 buzz box
Caterpillar TH63
'07 Kawasaki ZZR600
