I needed to do some work on my GA-20C gun, and had to disconnect the cable in the whip from the power/gas/etc connector, by unscrewing the nut on it. Now, when trying to put it back together, I can't get the wire to stay in place. I have the nut over the wire, push the connector down into the gas line, then go to tighten the nut... But as I try to get the nut to the threads, it compresses the wire, either squishing the strands back out or pushing the power connector forwards. I've tried pushing on it, I've tried maintaining constant pressure while turning, and everything else I can think of, but every time I end up with no wire in the connector by the time I get the nut to the threads. What's the trick for getting these together?
Here's a photo, if it helps anyone see what I'm talking about:
Thanks!
--Bushytails
Thanks!
--Bushytails
