While I was picking up some back order items at my Local Airgas I was informed that the price increase for acetylene has arrived they have double approximately. For all sizes and they are going to have a limited number of assorted sized cylinders available.
The price increase has arrived !
I am convinced that this increase is just Airgas. My local dist says no increase is comming and the prices have been the since last fall. I talked to a few other dealers and they said the same thing. But the Airgas guy said increase and at least 2 years until its normal again. One guy said his gas comes from Europe so the explosion in Ky didn't hurt his supply. Just my thoughts...BobBob Wright
Oh yeah, standard Airgas tactic.
Time to review your contracts.Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
PTsideshow,
I suspect you are being taken advantage of.
Last week, I swapped out my 330 cu ft argon tank for $36 and just asked about the acetylene issue and was told "no problem - no increase from us".
Very interesting as I don't buy acetylene from them although I have been an argon customer for 30 years.
Told my counter guy that I switched to MAPP about 25 years ago as I was getting clobbered with the demurrage fees since I didn't use enough to swap out a tank within the 30 day period. Then I had to switch to propane when MAPP was discontinued.
He told me, "If you want to switch to acetylene from propane, just say the word and I'll set you up with none of that baloney."
Plus he said, we are back to April pricing on acetylene.
Wow - talk about customer service!
Time to turn back the clock and go back to acetylene.
I suspect that those distributors who try to take advantage of the "shortage" will be like the gas station crooks. We will go elsewhere.
My supplier is in NJ about 4 miles east of center city Philly.
http://superiorweld.com/Miller Dynasty 350, Dynasty 210 DX, Hypertherm 1000, Thermal Arc GTSW400, Airco Heliwelder II, oxy-fuel setup, metal cutting bandsaw, air compressor, drill press, large first aid kit, etc.
They can only do what the corporate office hands down, It seems to vary as to the amount of the new price and where you live and where and how the acetylene is generated.
In the SE Michigan area, it is generated by the use of calcium carbide.glen, If your not on the edge, your wasting space
Originally posted by Country Metals View PostSpeaking of different gases, is anyone using propylene (sp)? I was wondering how it is.
I bought a tip for propane since I had a regulator for propane/acetylene(marked as a fuel gas regulator) and some new T grade hose I set up a second cutting station on an extra cart.
Propane tip on Rego KX-6 torch body
Two piece propane tip
Business end of tipglen, If your not on the edge, your wasting space
Funny how they are increasing their prices and blaming the illusion of a shortage.
Airgas makes their own acetylene.
What really sucks is that Airgas is buying up ALL the local companies in my state.Measure twice, cut ONCE............
MillerMatic 211
MillerMatic 251
Miller Dynasty 200 DX
ESAB O/A Equipment
Airgas and Praxair are buying up all the small timers they can every where.
Since they do use calcium carbide in their production of acetylene, and the largest producer of calcium carbide in the US was take out of production loop.
Since welding use of acetylene only makes up about 20% of the end use of acetylene. And plastics and chemical formulations use the rest.
And the can charge what the want or what the customers are willing to pay for it.
There are plenty of choices of alternate fuels for cutting and heating other than acetylene.!glen, If your not on the edge, your wasting space
Propane works great and cutting tips are cheap so there's no reason not to grab a few.
You can slosh propane jugs (I use the BBQ variety) around and not have to wait for it to settle like acetylene. A BBQ jug is lighter and easier to carry than an acetylene cylinder.
I've read (in this forum) that propylene works even better, but I haven't had an excuse to try it yet.
