does fluxcore require a different munipulation than reg. wire?
  • does fluxcore require a different munipulation than reg. wire?
    So yesterday I ran flux core for the first time ever and it seemed to run different than the regular MIG wire we have. Was it just me being nervous because the smoke was crowding my helmet or does it require a different movement ? Because just regular MIG wire with argon I can just drag and produce a nice clean bead ?
    Are you talking innershield or dual shield wire, as dual shield has no polariy change unlike innershield which requires the change.
      reply
      If I'm not mistaking dual shielding is flux core wire plus a tank of either argon or some mixture of shielding gas together ? I was only running flux core wire mostly because it came with the welding machine when I bought it from airgas. And I had never used it before.
        Justin,
        Fluxcore welds most like solid wire only without gas. sometimes your going to run a straight stringer, a weave and sometimes a side to side or even a zig/zag. Depends on if you are 1G, 2G, 3G up or down, or a 4G.
        I am not the final word on this but have run 100s of lbs of both. Not so much on the dual sheild.
        My fluxcore welds look like a cross between my stick and mig, my technique, everybodies different.
        The gas you will use with solid wire is a 75/25% mix of Argon/Co2. Pure Argon would be for aluminum mig and all tig opps.
        Your polarity will be different for solid vs fluxcore.
        Dual shield wire is not fluxcore wire with gas.
        Go to hobart or lincoln(their websites) and check the difference between the two.
        Most dual shield wires prefer pure Co2, but a bunch are happy with the mix gas.
        Of coarse there is slag with fluxcore and dualshield wires which makes the bead appearance different with each.
        Fluxcore more like stick and the dualsheild I have run is a real pretty, smooth bead that ties in nice.
        Different wires for different jobs and conditions.
        Practice...Practice
        Live Right Have Fun
        XMT350 CV/CC
        22A Feeder
        MM175
        TB302
        12vs Extreme
        Hypertherm PowerMax 1000
        20" x 40" CNC Mills (2)
        16" x 60" engine lathe
        65 Ton edwards iron worker
        3/16' x 24" power slip roll
        16' power feed mitering bandsaw
        and other fun toys
          Originally posted by 1havnfun View Post
          Justin,
          Practice...Practice
          I dont want to pick on anybody, but dual shield as always been known as a flux core or tubular wire. Any wire that produces slag as welded, is tubular wire filled with flux.
          A.K.A. fluxcore
            Daniel your right .... But
            Daniel
            So for the Newbes I listed according to Polarity and not anything else.
            That's it
            Live Right Have Fun
            XMT350 CV/CC
            22A Feeder
            MM175
            TB302
            12vs Extreme
            and other fun toys
              Just to clarify
              also when I stated that
              Dual shield is not fluxcore with gas.
              Just to clarify
              If you are using INNERShield type fluxcore adding GAS is NOT the SAME as using DUALSHIELD
              just thought I would state that before some else did.
              And I know some will.
              Live Right Have Fun
              XMT350 CV/CC
              22A Feeder
              MM175
              TB302
              12vs Extreme
              and other fun toys
                fluxcore
                As stated above from steel wire with gas switch polarity, also instead of pushing as you do with mig, drag at a slight angle, like stick you dont want to push your slag into your weld, so a 5 to 10 degree drag .
                Richard
