Need to join a 8" 1/4 wall pipe 90 degree to form a T,I know I can keep triming to get a good fit by trial,is there a good way to mark it to start with? Thanks, MAKINGSPARKS
Pipe Fiting
Originally posted by MAKINGSPARKS View PostNeed to join a 8" 1/4 wall pipe 90 degree to form a T,I know I can keep triming to get a good fit by trial,is there a good way to mark it to start with? Thanks, MAKINGSPARKS
Are you making the T joint out of 3 pieces or 2?
That would help to know
Thank you for your time and consideration.
Sincerely,
KentWelding is an art. But is also science in action. Chemistry and Physics. Got to love it.
simple! wrap a piece of cardboard or any other suitable material around the 8" pipe, tape it together, slide it off, place it 90 degrees to the pipe being welded, trim excess cardboard until it fits snuggly to pipe, when you are happy with the result, place this template on the pipe that will be cut, mark the pipe then cut away
Try this link: http://metalgeek.com/static/cope.pcgi
It will let you put in your pipe dimensions and print out a coping pattern. Cut out the pattern, wrap it around your pipe, mark it and cut it!Miller Syncrowave 200
Homemade Water Cooler
130XP MIG
Spectrum 375
60 year old Logan Lathe
Select Machine and Tool Mill
hey man, just making sure i understand u correctly. r u talking about a saddle. if so there is a right way to do it. by no means saying everyone elses way is wrong. if you are going to be doin a lot of pipe work i would recommend going to your local weld shop and purchase either some templates or the Frankland book. thats the author. or the pipefitters blue book. most welding shops around here carry both. if i could remember how i would tell you but i cant. i can remember how to layout and cut the lateral but for some reason not the branch. it's been awhile, we dont make our own very often. ne way hope this helps
