Hi Guys,
OK, so I'm Just think out loud here...
I have read that you sometimes sharpen the wire to a point to get the puddle started with some of the wire feed methods... Can I do the same thing for a stick weld?
I'm having trouble with a little bit of blowthrough on thin metal. I'm repairing an rusted out automotive saddle, and while I've cut it back as far as possible to get to some clean metal, there are still a few places that are a little weak, so I need to get the amps down a touch. Only trouble is I can't get it to arc if I turn it down, it just sticks like glue.
So I'm thinking if I sharpen a bit of a point on the stick it will be easier to start without sticking, and then I would be able to run a bead at a lower amperage and not blow through the material so much.
Has anybody ever try this?
Got any other tricks up thier sleeve?
I'm using a 115V ac only stick welder with 1/16" 6013, and this is all that I have.
(Please save the pokes and jabs about the equipment for another time... I'ts all I have right now, and in 1/16", 6013 seems to be the only rod available.)
Thanks,
Hobbynut
Thanks,
Hobbynut
