another aluminum question
  • another aluminum question
    I am kind of new welding aluminum with our mig at work we have a Hobart Handler 175 we got 30cm aluminum wire and using argon gas. My problem we are having is the mig keeps jamming the wire at the feed gear. I hear talk about a push pull gun do we need this type of gun to get the wire to stop jamming. Or what are we doing wrong with the settings. thanks.
    hmm
    you need a spool gun trying to push aluminum through a regular gun and cable is like trying to push a wet noodle up a hill
      ok thanks! i kind of thought we would need another type of gun.
        I believe some guns have teflon liners available for feeding alum. Call your LWS for availability.
        5356 feed better than 4043 if that matters.
        Miller Dynasty700DX
        3 ea. Miller Dynasty350DX
        Miller Dynasty200DX
        ThermalArc 400 GTSW
        MillerMatic350P
        MillerMatic200 with spoolgun
        MKCobraMig260
        Lincoln SP-170T
        Linde UCC305 (sold 2011)
        Hypertherm 1250
        Hypertherm 800
        PlasmaCam CNC cutter
        Fadal Toolroom CNC Mill
        SiberHegner CNC Mill
        2 ea. Bridgeport
        LeBlond 15" Lathe
        Haberle 18" Cold Saw
        Doringer 14" Cold Saw
          Some guns don't take the heat well from a mixed gas so be carefull how long you run it...Bob
            thanks guys went to the Hobart site and the gun and controler I need are availible for the welder. It needs a 3035 spool gun and a GMA100 controler. Now all I have to do is get our boss to get it for us!
              Good deal thats the best way...Bob
                hmm
                the best way is a push pull pulse setup first show him the cost of a miller 350p aluma pro and tell him this is the best for the job then show him the 3035 and controller and say but we can get it done with this
                  What are you trying to weld? something complex or simple? how thick?...Bob
                    Expensive route and you still only have a 175 amp machine
                    3035-20 spoolgun - $479.00
                    SGA-100 controller - $239.00
                    $718.00 to run a spool gun that way
                    B&R welder has a Spoolgun adapter kit $359.00
                    http://brwelder.com/indextemplate.cf...ubCategory=269
                    or...Hobart Handler 210 WITH spool gun @ Northern $949.00
                    http://www.northerntool.com/shop/too...2663_200392663
                    Ed Conley
                    MM252
                    MM211
                    Passport Plus w/Spool Gun
                    TA185
                    Miller 125c Plasma 120v
                    O/A set
                    SO 2020 Bender
                    You can call me Bacchus
                      Thats for sure...Bob
                        If you're stuck using the same set-up until your new gear arrives try running 5356 wire & ream out your contact tip with a tip cleaner, might help you get by.
                        Miller Trailblazer's ( 2 )...MillerBobcat 250...Millermatic 251's ( 2 )...Miller Syncrowave 200...Miller Syncrowave 180SD...Miller 12VS Suitcases ( 2 )... Hobart Hefty CC/CV Suitcases ( 2 )...Miller 30A Spool Guns ( 2 )...Miller WC 15A Control boxes ( 2 )...Thermo Dynamics Cutmaster 50 Plasma Cutters ( 2 )...Thermo Arc Hi Freq Units ( 2 )...Smith / Victor O/A Sets...DeWalt Power Tools...Craftsman / Snap On Hand Tools... Two Dodge Mobile Rigs
                          If you do use your welder and whatever feeder i would stick with .030 sized wire. It tends to work better on smaller machines...Bob
                            yup if it was me i would go the 210 route more juice and a gun plus youll have an extra machine
                              we use it to repair handcarts and repair the shelves in the trucks they are all aluminum. at the most maybe 1/8 inch thick.
