211 ruber feet?
  • 211 ruber feet?
    Just picked up a Miller 211 to make my rock crawler and love it. I got it on sale and it came with a standard cart. The welder slides around on the cart. Is the 211 suposed to have rubber feet on the bottom or am I suposed to take the welder apart to access the holes inthe bottom and bolt it to the cart?
    Definately fasten your machine to the cart. Another thing you might consider as a useful option, is to remove the tiny wheels on the cart, replace them with something a bit larger/softer so as to move it a bit easier over rough terrain in the yard, gravel driveways and such. The wheels on most new carts of late are smaller and good for a perfectly flat shop floor only.
    I did all that (above) to both my smaller machines then recently got a Passport Plus. Should have bought it long ago, great grab and go rig.
      Rubber Feet
      You could put rubber feet on it. Some have tapped holes already there.
      Or a piece of rubber matt and some kind of belt or strap to hold it down.
      Or bolt it down.
      Good Luck,
      Bob
      Millermatic 252 w/30A
      Big Blue Air Pak
      Ellis 3000 Band Saw
      Trailblazer 302 Air Pak w/ Wireless Remote
      8-RC
      XMT 350 MPa w/S-74 MPa Plus
      Millermatic 211
      Passport Plus
      Spectrum 625 X-TREME
      Lincoln SA-200 Blue Tint Red Face '63
      2-Lincoln SA-200 Red Face '68
      SA-200 Black Face '59
      SA-200 Green Lite '84
      SA-200 Green Lite '80
      SA-200 Red Face '69
      SA-200 Red Face '66
      SA-200 Green Lite '81
      '70 Black Face Round Barrel
        Thanks for the responces. I wanted to make sure i was not missing a part. I had some rubber mat so i cut a peice to fit the top tray. Now the welder stays put but i may ad bolts as well.
        Good tip on the larger wheels.
        I have been using a SnapOn 110v MIG for a few years on loan from a friend. He is moving so I got my own and went for the 211 upgrade. It sure is sweet. Now i need to run my 240v outlet.
        Also need a 240v extension cord and i will be all set.
          Or bolt it down.
          Good Luck,
          Bob
          i bolted my 175 down to keep it securely mounted in case of tip over. my plasma cutter i strapped down since i didn't have to open the side door.
          hey Bob you got your ark built yet. i lost a butt load of trees in the wind last night.
          miller 225 bobcat
          miller aead200le (with miller hf tig trailer mounted)
          mm175, mm211, TA181i
          mm252 w/30a spool gun
          precision tig 225
          hobart stickmate LX ac/dc
          Speedglas 9100X & XX / Miller Digital Elite
          hypertherm 380 & cutmaster 52
          victor journeyman & super range
          ridgid chop saw, kalamazoo band saw
          steel max and evolution carbide saws
          6 4.5" & a 20lb 9" rockwell grinders
          case 580 backhoe (for what i can"t lift)
          if first you don't succeed
          trash the b#####d
            Trees
            Jim, I havn't looked yet, the weather lady said 3-5'' of rain this week. I hope to have the arc done by the end of the week, when the flood starts.
            To the OP I have my plasma tied down with big zip ties. That's only temporary, until I build a proper cart.
            Good Luck,
            Bob
            Big Blue Air Pak
            Ellis 3000 Band Saw
            8-RC
            Millermatic 211
            Passport Plus
            SA-200 Red Face '69
            SA-200 Red Face '66
              Both my MM180 and my little 375 Extreme plasma cutter are held in place on the cart by gravity alone. Neither of them have ever given any sign of wanting to float away. I did put slightly larger wheels on the factory cart that came with the 180. I also built a frame addition in order to piggyback the plasma on the same cart. I intended this setup to be temporary but it has worked fine for so long now I do not see any point on wasting time and material building something "better"......
              Larry
              "I feel for the man who can only spell a word one way"......Mark Twain
              Lincoln AC225-S (OLD/Copper Wound)
              Lincoln Weldpac 100
              Miller Matic 180 (auto set)
              Miller Spool gun 100
              Miller Spectrum 375 Extreme
              Victor Super Range II
                My 211 and 375 also sit on the same cart with gravity holding them down. I've pulled this from my shop to the front of my house through the grass with great effort, and nothing moved.
                Think about bolting it down. If you do and the need arises to move the 211, you have to take the cover off, unbolt the welder, and then put the cover back on. Then when you're done with your project, reverse the process. Seems like a bunch of work to me for little gain.
                But, it's your welder, your cart, and your decision. I just related what works for me. YMMV.
