Spatter at the Aluminun MIG welding
  • Spatter at the Aluminun MIG welding
    Hi Friends.
    I have a Millermatic 212 with spoolmatic. All welding show a spatter and smoke around the weld. I tried with different parameters and the result it same. How can I to do for eliminate these problems?
    Thanks.
    You'll have to list YOUR parameters because we can't read minds.
    If the wire is coming out and the gas is good it usually is the Contact Tip to Work Distance
    Ed Conley
    MM252
    MM211
    Passport Plus w/Spool Gun
    TA185
    Miller 125c Plasma 120v
    O/A set
    SO 2020 Bender
    You can call me Bacchus
      I don't worry about the black stuff. Its impossible to get perfect welds with the repair work i do...Bob
      The experts at FMA answer a question about how to recognize and minimize weld smut that occurs when welding aluminum. Learn more about aluminum smut here.
        Be sure that you are pushing the weld. The black smoke will always be there. It will be IN the bead if you pull. It will come off with a wire brush.
        AutoArc 230 (MM 210)
        3035 spoolgun
        Spectrum 625
        Dialarc HF w/Coolmate 4
          1. Type of gas for coverage? You should be using Argon for aluminum.
          2. Polarity?
          3. Stickout?
          4. Push or pull?
            alum likes to be pushed. as far as the spatter thats aluminum i run my stuff at about 20 volts and like 400 imp
            weld to live live to ride
