A friend of mine said i can use his syn350 system and I've used his tig on this system but I was wanting to use the stick side on the system. I put the other lead in the system and set the system so the stick was lit and still no spark. any ideas?
Help syn350 stick?
Remote
Unplugging the foot pedal may be enough, it was for my Synchrowave 180. Look also for a front panel switch that might say "remote", and flip that off.
If you think about it, with TIG, the tungsten is not live unless you push the foot pedal, so if stick is dead, that is probably tied to the foot pedal in one way or another.
You could also download the manual for the unit, which should explain this.
RichardSyncrowave 200, Millermatic 211, Victor torch, Propane forge....
