Bobcat 250 vs 225
  • Bobcat 250 vs 225
    What are the main differences?
    Spenser -- Check the Miller website and use the compare feature for these two units. This should provide you with that information.
    Bill
    Miller Bobcat 225
      what about the 250 makes it capable of fluxcore?
        The 225 is also "capable" of flux core but the 250 is "designed" for flux core per the product literature http://www.millerwelds.com/pdf/spec_sheets/ED4-4.pdf most likely due to its higher amp/weld voltage capacity.
        Syncrowave 180 SD
        *HF-251D-1
        *WC-1S & Spoolmatic 1
        PakMaster 100XL
        Marquette "Star Jet" 21-110
          In addition to the items listed on the web site that the guys referenced, the Bobcat 250 Stick welds better, especially with 7018 electrodes. It also has considerably more CV output for running wire: 275 amps at 25 volts versus the Bobcat 225 which is 200 amps at 20 volts. The quality of weld output to run wire on the Bobcat 250 is a lot better as well. As duaneb55 stated, it's the difference between capable of and designed for.
          My money would go towards the Bobcat 250 every time when comparing the two.
          Have a great day!
          John Leisner
          Product Manager
          Miller Electric Mfg. Co.
          Owner and user of:
          Trailblazer 302 and Legend 301
          Smith Dual Guard oxy-fuel system
          Various borrowed Millermatics and Spectrums.
