Bobcat 225 NT Weld Aluminum
  • Bobcat 225 NT Weld Aluminum
    Hi all,
    I am new to the forum. We have a Bobcat 225 NT with a "Suitcase" mig that rarely gets used. Pretty much all of our welding is stick on 30+ year old tractor equipment. What would be the best avenue to do LIGHT aluminum welding? For example I need to replace the front deck in my aluminum boat along with other assorted items.
    Regards,
    RajunCajun
    Little more info.
    I think the suitcase is an 8vs. I am not familiar with mig so have not used it. We purchased the 225 used with a couple hundred hours on it and it included the suitcase. As I look at the specs of the 8vs it is supposed to be capable of Aluminum but I am not sure if I would have to purchase a spool gun or some other accessory.
    Thanks in advance for your assistance.
      You'll be needing a WC-115 with contactor and a spoolmatic 30A.
        Thanks for the advice but that is a little out of my price range. Do I have any other options?
          Ok, Google tells me that its theoreticaly possible to feed aluminum wire through a Mig welder. Some mig welders have kits that change the rollers and liner. Given the limited nature of the Aluminum welding I want to do, can the Suitcase be setup for aluminum?
            Yes but you'll go through more wire than being welded, untangling wire birdnests every few seconds.
              rig
              I have one of those rigs for aluminum I'll sell you for $1000.00 plus UPS postage....it's the WC-115-A and Spoolmatic 30A spool gun. Hadley Perdue 707-202-0014 Athens Ga.
                aluminum welding rig ---with corrected telephone number
                I have the equipment you need. Call me at 706-202-0014. Thank you Hadley Perdue
                  I have the equipment you need, see the description nearby. Thank you ,Hadley Perdue 706-202-0014
                    Ok, I know I am setting myself up for frustration but I cannot justify (to myself or the wife) spending $1000+ for the very small amount of Aluminum welding I need to do.
                    What I need to setup the suitcase to run Aluminum?
                    BTW... I know I will be kicking myself later, but I had my skull replaced with 1/2" mild steel and now no good advice can get through.
                      welding aluminum
                      take a look at the readywelder battery powered spool gun, can be hooked up to your welder. just got mine and have been fooling around with it and like it alot. bought mine here in canada for $640.00. diverdown
                      sigpic2001 Dodge Ram welding truck. Hobart champion 10.000, miller Diversion 165. miller 180 autoset with spoolgun. SIP plasma cutter. Airless plastic welder.1996 28 foot bayliner for hauling dive and welding equipment
                        Very Interesting, let me know how it works for you.
                          Try the 8 VS
                          You could try your 8 VS. Get the shortest gun you can find, like the Bernard S series 8' long or shorter. Keep the liner/hose straight as possible when welding.
                          My Millermatic 90 fed Al through about a 10' gun. I did have my share of birds nest though. It's a pain, you have to pull the gun out, cut off the wire, pull it out of the liner, and restring the gun. It worked ok for little things, couldn't do any real work.
                          I finaly sold it to a guy that just did mild steel.
                          Use the small rolls of Al in case you have to go to a spool gun.
                          Good Luck,
                          Bob
                          Millermatic 252 w/30A
                          Big Blue Air Pak
                          Ellis 3000 Band Saw
                          Trailblazer 302 Air Pak w/ Wireless Remote
                          8-RC
                          XMT 350 MPa w/S-74 MPa Plus
                          Millermatic 211
                          Passport Plus
                          Spectrum 625 X-TREME
                          Lincoln SA-200 Blue Tint Red Face '63
                          2-Lincoln SA-200 Red Face '68
                          SA-200 Black Face '59
                          SA-200 Green Lite '84
                          SA-200 Green Lite '80
                          SA-200 Red Face '69
                          SA-200 Red Face '66
                          SA-200 Green Lite '81
                          '70 Black Face Round Barrel
                            I think you'll be very dissapointed with a standard feeder. Even with short guns, they will not feed well as soon as the gun is not perfectly straight. If you want to stay with that machine and a low cost, 2 options that come to mind are:
                            1. Spoolmate 3035 spool gun with an SGA 100C control.
                            2. Millermatic 140, 180 or 211 with a Spoolmate 100 series gun. This would also allow you to run wire in your shop.
                            Have a great day!
                            John Leisner
                            Product Manager
                            Miller Electric Mfg. Co.
                            Owner and user of:
                            Trailblazer 302 and Legend 301
                            Smith Dual Guard oxy-fuel system
                            Various borrowed Millermatics and Spectrums.
                              As John said, you will most likely be disappointed.
                              I have no personal experience here, all aluminum I've ever done was with a spoolgun or TIG.
                              If you want to increase your chances of success,,,,,,,
                              Use 5356 wire. It's harder and stiffer than 4043.
                              Minimum wire size 1/16".
                              Use a dedicated teflon liner, don't ever run steel thru it, it will contamintate it.
                              As previously stated, short and straight is good.
