why is this
  • why is this
    Ok I have a Sync 200 and am tigging steel on dcep...160 amps. The arc will start, make a puddle and I start to add filler and then without lifting my foot off the pedal pushed to max, the arc will get smaller and less power and then it may get to full power again without me changing anything. ??????????
    Nick
    Miller 252 Mig
    Miller Cricket XL
    Millermatic 150 Mig
    Miller Syncrowave 200 Tig
    2-O/A outfits
    Jet Lathe and Mill
    Jet 7x12 horz/vert band saw
    DeWalt Multi Cutter metal saw
    Century 50 Amp Plasma Cutter
    Propane Forge
    60" X 60" router/plasma table
    Does it happen when your running in pulse? Cause that pulse runs from where ever you set your peak amperage to where ever you set your low or background amperage
      Not that it addresses your problem, but shouldn't you be tigging steel on DCEN?
        Arc length.
        You don't realize it, but you're changing the tungsten to work length.
        Syncrowave 250 DX Tigrunner
        Miller MM 251 w/Q300 & 30A SG
        Hobart HH187
        Dialarc 250 AC/DC
        Hypertherm PM 600 & 1250
        Wilton 7"x12" bandsaw
        More grinders than hands
          Not sure what SundownIII is saying.
          SundownIII can you explain?
          "You don't realize it, but you're changing the tungsten to work length."
          Just asking.
            What he is saying is he may be moving the torch closer then farther away then back close again.
            Its easy to mistakenly do as you start moving both hands in sync.
            Adding filler with one hand and unknowingly moving the other hand with the same motion.
            Just maybe Sundown is correct.
            Only other time I seen something similer is from running the welding machine from a gas generator that couldn't
            keep up.
              keep up.
              Ok...I understand.
                The switch is to the left..electrode negative....the pulse was on but set at the lowest. I turned pulse off totally and tried again. It didn't do it. I'll do more checking.....thanks guys
                Nick
                Miller 252 Mig
                Miller Cricket XL
                Millermatic 150 Mig
                2-O/A outfits
                Jet Lathe and Mill
                Propane Forge
                  Monte: What's the material thickness? I rarely use the pulser, unless it's thin material. Tungsten type?
                  As Sundown mentioned, it's easy to "pull back" on the torch, which changes your arc length. As a rule of thumb, arc length should be one electrode diameter.
                  Remember, this is a CC process, and like SMAW the voltage (electrical pressure) varies with arc length.
                  "Bonne journe'e mes amis"
