Sitting here trying to watch a football game I care absolutely nothing about. I have a large welding table that I fabricate gates on and am wondering if there is a cheaper solution to anti spatter spray to keep the table clean of spatter. I typically clamp everything up then spray the areas where welding is going to happen. Just curious if there is some kind of cheap wipe-on or spray on available. Thanks for your time.
Anti spatter
There is a water soluble spatter spray that comes in 5 gallon buckets and you can get a trigger sprayer bottle at your local home improvement store for about a buck. I think I paid under 100.00 for a 5 gal bucket of the stuff and will last a long time.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
Too many other tools to list
03 Ram 1500
78 GS1000
82 GL1100 Interstate
Here is the real problem. Watching a football game that you don't care about. How is that possible?????? Us up here in the cold state of Wisconsin aren't thinking about welding and anti splatter except anti splatter on the field.
Dynasty 350 - My New Baby
Millermatic 210 Mig with Spoolmate 3035
Miller Thunderbolt XL 225/150 AC/DC Stick Welder
Miller Specturm 625 Plasma Cutter
Speedglas 9100 auto dark helmet
Jackson auto dark helmet
18.5 CFM Eagle Compressor
Oxy/Act
Horizontal Band Saw
Dewalt 14" Chop Saw
7 1/2 Dewalt Angle Grinder
4 - 4 1/2" Sears Angle Grinders
1 - 4" Makita Angle Grinder
2 - IR Die Grinders
All of which my wife says will be a "he$$ of a garage sale"
I use the kitchen anti stick spray what ever is the cheapest at the store. Arcet sells the stuff to it is about $3.70 a can.Lincoln Vantage Kubota diesel 30 amp spool gun , Hobart 210 with spool gun, Thermal dynamic pak master 75, miller 304xmt all mobile all ready to go.
Originally posted by aametalmaster View PostI had some problems with the water soluable stuff as it was rusting all of my parts esp in the summer when it was real humid out. My train bridges have way too many small parts to wipe off after welding...Bob
I'm reading about products I've never heard of for spatter control. I've never heard of using Pam before or used engine oil. I guess that just proves there are just about as many solutions to the problem as there welders out here.Blondie (Owner C & S Automotive)
Miller 340A/BP
Victor O/A torches
Lincoln SP125
03 Ram 1500
78 GS1000
i have used Pam/vegetable oil spray on my table but it tends to be to sticky for my taste lol. i have never used "used" motor oil but i often use new motor oil cut with paint thinner to ease the spreading. once the thinner flashes off it leaves a nice even film on the table that isn't so sticky that it gets all over the metal your welding. you might be a redneck if you use bacon grease and have a hen roosting in you refrigerator/rod oven.miller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####d
I just bought some stuff from my LWS called Jokich. Its made in Germany and it wasn't all that cheap, bout $45.00 per gallon. I put it in a pump-up insecticide/bleach sprayer from Home Depot. I sprayed a coat over my table yesterday and have built 4 ranch gates on it today, and have not had any spatter issues. I would imagine a gallon should last me at least a year or better. Thanks for all the ideas offered.
Fuzzy
Originally posted by FUZZYTX View PostI just bought some stuff from my LWS called Jokich. Its made in Germany and it wasn't all that cheap, bout $45.00 per gallon. I put it in a pump-up insecticide/bleach sprayer from Home Depot. I sprayed a coat over my table yesterday and have built 4 ranch gates on it today, and have not had any spatter issues. I would imagine a gallon should last me at least a year or better. Thanks for all the ideas offered.
Fuzzymiller 225 bobcat
precision tig 225
trash the b#####d
Antispatter
I weld 8+ hours a day for a living. I don't use antispatter spray except on high dollar jigs. At the end of the day I use a 60 grit flapper wheel to knock the spatter of my welding tables and smooth off the top. Another option is tacking or clamping a 3/8" plate to the table top and changing it out every so so often
Most times you can minimize spatter by correctly adjusting the wire speed, voltage, and use 92/8 for shielding for GMAW. Also the more welding you can run spray arc the less, if any, spatter you will get. For SMAW set your heat right and spatter is almost non-existent. Aluminum work tables is another option if you can afford it. My 2 cents.
Spatter with GTAW is non-existent.
Good Luck.
HAWKLast edited by HAWK; 02-09-2011, 10:50 PM.
