Keeping Hood Lenses Clean when Working with SMAW or FCAW
  • bigtow30t
    When I know I'm going to be welding a lot that day, I have a micro fiber rag in my back pocket (at least near by). You can get them at the dollar store. It's not going to stop all of the scratches but it's got be better than using your shirt. Or just lick it clean ;-)
  • Jtsharp
    Try getting a cheater lens for your helmet. ( magnifying lens) that should help so your not holding your face as close. Or try reading glasses.
  • Cgotto6
    Originally posted by MMW View Post
    Everything that others have said. Buy a stack of replacements, they are cheap. I clean mine with my hand, my glove, my shirt, etc., whatever is fastest. When they get to really scratched I put new ones in. Sometimes I can't believe the difference when I change the clears.
    I know what you mean. I go for a while without changing my lens protector then when I finally think to the next bead is always way bright and like HD clear.
  • metalmanipulator
    Miller Elite
    Love My Elite for years. The only problems I have Is the inside cover. While changing lenses out its hard not to mare the very sensitive inside lens. I gently on a clean surface carefully install then put scotch tape around sides to keep grinding dust from getting in between the auto-darkening and cover lens. The outer cover gets gets wiped on my sleeve a lot but too much arc splashes makes it hard to see as i tig. That is when I Know it is time to replace.Click image for larger version
  • Blondie_486
    Hillbilly69,
    That's good advice provided you can see at that distance. Myself if I weld that far away I can't see well enough to weld.
    As davedarragh has said I only use my "Big Window Elite" for TIG welding. For everything else I use a 25.00 Jackson helmet. By the way the new Jackson headgear is a big improvement over the original.
    The clears for the Big Window Elite are expensive in my opinion but the clears for the Jackson are cheap, I think I pay somewhere between .50 and .75 a piece for them.
  • Hillbilly69
    I'm Blind
    Take your face out of the Puddle
    They gave you arms so don't have to put your face in the puddle.... Increase your face to puddle distance by the length of your arms
  • davedarragh
    "Anti-Fog"
    Originally posted by kraythe View Post
    Greetings,
    I am having a big problem keeping my lenses clean on my miller digital elite helmet when doing SMAW or FCAW. I was wondering if anyone could offer any tips. It seems like after a short time (often only a couple long welds) the flux has built up on the lens so much that it makes it hard to see the puddle. Perhaps its my head position or weld position that is off. I am not a pro welder, just a hobbyist, so I am most likely doing something wrong. When using FCAW or SMAW, I find I **** my head to one side and get pretty low to see the puddle and what it is doing. I tried backing off but then the MIG gun obscured the weld puddle and I was practically welding blind with ... predictable ... results.
    So anyone have any idea what i am doing wrong or is this a common problem that someone knows a good tip on?
    Thanks in advance.
    Torch Wear makes an "Anti-Fog" lens cleaning paste that you apply to new lens covers, and helps significantly. I use my old trusty Fibre-Metal Pipeliner hood for SMAW, FCAW, and CAC-A, and save the $$$$$ Miller Hood for GTAW and MIG. The lens covers can get expensive for those "Big Window" hoods.
    I think Cyberweld sells the Torch Wear Lens paste.
  • MMW
  • nfinch86
    Paper towels !
    Originally posted by Blondie_486 View Post
    I use plenty of warm water and mild soap on a soft rag to clean my cover lenses then dry with a soft rag as well. I found that using lens cleaners and paper towels will scratch the lenses. I learned the hard way by ruining a set of 180.00 polycarbonate lenses for my eyeglasses that way.
    Blondie, The lense cleaner is OK, It's the paper towels ( wood fibre ) that scratched your lense !
    ........ Norm
  • Blondie_486
  • wronghand
    The original Lemon Pledge (the stuff WITH the wax still in it) works pretty good to clean cover lenses. Dustbane also makes a good glass cleaner.
  • Sandy
    I wipe mine on my shirt ..
    What do replacements cost?
  • kraythe
    Ok. Setting up a draft is a good idea. I can try that. So what is the best way to clean the lens now that it is dirty?
  • aametalmaster
    I stick weld in tool and die 8-12 hours a day and don't get any smoke on my hood. The guy next to me gets his covered and is always complaining he can't see because of the film. He asks how i keep mine so clean and i say i keep my head out of the smoke and use my arms out farther. I bought my hood in '79 and it still looks like new but it has 32 years of use on it...
  • GerryR
    It seems that getting stuff on the helmet and lens is inevitable, unless there is a good way to exhaust the smoke. I wipe down my helmet with ArmorAll, both in and out and it makes cleaning it much easier.
