torquing stainless steel bolts
  • torquing stainless steel bolts
    Did a torque inspection on about 100 bolts today. All the carbon steel checked out ok. The stainless steel not so. Nearly all out of 30 or so were loose. This was obviously embarrasing for the boilermakers. Now they are tight because I watched them do it. Assuming they did it right the first time, why would the stainless loosen?
    1. Was anything like thread lock or non-seize used on the threads?
    2. What type of torque wrench (beam or clicker) was used on the bolts?
      There was anti-seize applied to the bolts. A clicker type torque wrench was used
        SS has a much larger coefficient of thermal expansion than steel. Heating and cooling can easily loosen bolts. I always try to use tie wire or castle nuts to lock them down.
        John
        Miller Diversion 165
        1945 Craftsman Atlas Lathe
        Smithy Lathe/Mill
          You might want to ask this question to "ARP". They make a line of automotive fasteners that are stainless.
          http://www.arp-bolts.com/
          If I recall, their 12-point head bolts do in fact have a hole drilled through them for safety wire.
          Also, might want to look at this:
          http://www.arp-bolts.com/pages/techn...orque_us.shtml
          Con Fuse!
          Miller Dynasty 350
          Millermatic 350P
          -Spoolmatic 30A
          Hypertherm PowerMax 1000G3
            Were any or all of the bolts in blind holes?
