Just set up my 350 yesterday and have not even struck an arc! This is my first Bernard gun. It came with a jump liner that was not installed. I took the gun apart and it did not have a jump liner installed, but the liner from the machine was continuous to the the tip. I am assuming that the part of the liner that will fail first is at the neck of the guy and that once it does I can trim the long liner back and install the jump liner?
If the above is correct, when you change wire size, do you need to change the entire liner or can you just change the jump liner when going to a smaller wire?
Thanks,
Jim
Thanks,
Jim
