aluminum wheel rims
  • aluminum wheel rims
    what type wire "ER4043,ER5356 etc" should be used to repair aluminum wheel rims, what alloy is used in making wheel rims?
    Not a safe repair for the home handyman.
    Griff
      Griff
      How about a Motorhome handyman.
      I would suggest the strongest wire, 5356.
      Miller Dynasty700DX
      3 ea. Miller Dynasty350DX
      Miller Dynasty200DX
      ThermalArc 400 GTSW
      MillerMatic350P
      MillerMatic200 with spoolgun
      MKCobraMig260
      Lincoln SP-170T
      Linde UCC305 (sold 2011)
      Hypertherm 1250
      Hypertherm 800
      PlasmaCam CNC cutter
      Fadal Toolroom CNC Mill
      SiberHegner CNC Mill
      2 ea. Bridgeport
      LeBlond 15" Lathe
      Haberle 18" Cold Saw
      Doringer 14" Cold Saw
        Official answer:
        Don't do it! Welding on rims is unsafe, not warranteed
        Unofficial answer:
        5356 for truck/passenger car tires
        4043 for off road stuff like quads or 4x4 s as the rims flex quite a bit and your repair will last longer
        Big Blue 400D
        Trailblazer 302
        Miller S-32 suitcase
        12VS suitcase
        Lincoln LN-7 (BIG suitcase)
        Victor torches
        Lincoln 350MP with 35' push-pull gun
        Lincoln PrecisionTIG 375
        Spectrum 1000 plasma cutter
          aluminum wheels
          to WORNGHAND, from jerry spell. i have been a certified pipe welder sence 1962. i am only tring find what type alloy, and filler metal should be used. thank for your info and help.....
            A friend of mine who does a fair amount of aluminum tig on castings for Ford Motor company, one day when the engineers stopped by his shop they told him that rims are heat treated and that its not a good idea to weld on them.
            That being said when I used to do it I used 5356.
              How does a pipe cert, make you certified to weld aluminum wheels! I know that Les schwab will not put a tire on a wheel that has been welded!
              Miller Trailblazer 302
              Miller 12 RC wire feeder
              Miller HF 251D-1
              Miller 175 wire feed
                I weld aluminum wheels on Honda 4 wheelers and other off road vehicles that are used in the fishing industry on the beach of the Bering Sea ....I vee out the cracks and preheat the wheel and spool gun them with 5356....The ones that come in with chunks missing from the rim can be built up and ground or turned to shape if the missing pc is not too big......This is all off road use and for people that are in the bush and are only interested in getting back to work...Looks always take a back seat to function on weld jobs like this...The repairs seem to hold up as well as the original wheels in this very abusive environment...I have had local dump truck guys come to me wanting truck wheels welded .......I won't do it.....
                  Right on Bayweld.
                  I know exactly why you are preheating and mig with 5356.
                  5356 can sometimes overage the HAZ if you weld it cold with Mig.
                  I see a lot of alum wheels that have cracked on the inboard lip where there is no spoke support.
                  Miller Dynasty700DX
                  Miller Dynasty200DX
                  ThermalArc 400 GTSW
                  MillerMatic350P
                  MKCobraMig260
                  Lincoln SP-170T
                  Hypertherm 1250
                  Hypertherm 800
                  2 ea. Bridgeport
                  LeBlond 15" Lathe
                    Depends on what you are going to use them for.
                    Off road use = Who cares go have a blast.
                    On road= Don't come through California with them. If it should fail and in the investigation it's found out that the rim fail due to being welding upon. Guess what. Illegal and unsafe repair of a safety device. Same would be true for machining a set of rotors to thin and killing your self or someone else.
                    I know rim ain't cheep but they ain't worth the risk either Not for on road use
                    South bend lathe 10LX40
                    K.O. Lee surface grinder 6X18
                    Auto shades are for rookies
                    www.KLStottlemyer.com
