I am in my welding certifications classes. I am kinda new at welding but I'm good at it. I am ahead of my class and no one knows anything about vertical welds but my instructor. He is usually doing something and don't want to bother him. I need some good tech. for this type of weld. I am haveing problems weaving tighter beads. My welds look great according to my instructor but he says they are a little too wide. When I try to weld within the tow of my root pass I still weld too wide. How can I fix this problem.
Need help with vertical welds.
Originally posted by Westside Welder View PostI am in my welding certifications classes. I am kinda new at welding but I'm good at it. I am ahead of my class and no one knows anything about vertical welds but my instructor. He is usually doing something and don't want to bother him. I need some good tech. for this type of weld. I am haveing problems weaving tighter beads. My welds look great according to my instructor but he says they are a little too wide. When I try to weld within the tow of my root pass I still weld too wide. How can I fix this problem.'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Invertec V205T-AC/DC
Miller 12VS suitcase
Miller spectrum 2050
Pipe beveler's
Track torch
my guess is your running stick, 7018? what is the thickness of the metal you are welding V-Up on? Try holding your corners for 3 seconds 1 one thousand 2 one thousand 3 one thousand. That helped me to eliminate slag inclusion, and to get a better looking bead appearance. After a while of doing that I didnt have to count anymore and I now know what to look for. Also, try not to come out of your puddle when stacking your weld. I always try to come out slightly so that it almost looks like im going over top of the already applied metal, hold 3 seconds, then shoot across the middle and hold again on my corner and so on. Gravity is really working against you on V-Up welds so you have to take it slow. Hope this helps
If your are using 7018 3/32- turn down your heat to tighten up your width. the hotter you are the wider you have to run, reguardless of what your welding, plate, pipe, fillets.
Try running around 86 amps, it will be slower but easier to keep narrower. As you need to get wider turn up the heat a little each pass.
You need to give more and better info! I could care less what your instructor is doing or the rest of the class for that matter. If you want good advice give good info.
-Type of machine and its settings.
-rod type and size
-material thickness and joint type,
-position
-problems your having.
I don't mean to be rude but this happens a lot and its getting old. Oh, and tell your instructor to help you. He should spend the same amount of time with you weather your the fastest or slowest learner. You have to get what you paid for.'08 F-350
Vantage 400
SA-250
SA-200
Invertec V350Pro
Pipe beveler's
Track torch
Originally posted by Rig Hand View PostIf your are using 7018 3/32- turn down your heat to tighten up your width. the hotter you are the wider you have to run, reguardless of what your welding, plate, pipe, fillets.
-rod type and size
-position
I don't mean to be rude but this happens a lot and its getting old. Oh, and tell your instructor to help you. He should spend the same amount of time with you weather your the fastest or slowest learner. You have to get what you paid for.Miller Syncrowave 200 W/Radiator 1A & water cooled torch
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
-rod type and size
-position
I'm using a Lincoln Electric IDEALARC 250. I'm running about 97amps
I'm using E7018 1/8" rod.
I think its like 1/8" metal.
I'm on Vertical T-Welds 3F
I'm haveing a problem with my welds being too wide. I weave fine its just my pauses are off, or my machine is too high or low.
I figured I would ask some people than may have been through the classes before and know what they are looking for. I thought maybe a good welder could tell me a little about how he does his vertical and could give me advice.
