Miller Syncrowave 351 TIG problem HELP
  • Miller Syncrowave 351 TIG problem HELP
    All of a sudden having problem with holding arc. It will strike an arc for a short time then just hiss with a fine blue spark leading from tungsten to the work. I checked all connections and played with all settings etc but no luck. Worked fine before this.
    Does it work on stick?
    I suggest that you try it on stick mode, and see what happens. That will give you some idea where to start looking, whether it will weld stick or not.
    Note that if you see HF arc but no power, that points to a bad connection somewhere, maybe even a ground cable disconnected. ;-)
    Richard
    Syncrowave 200, Millermatic 211, Victor torch, Propane forge....
      A customer of mine has a sync 250 with the same problem. I loaned him an extra foot control of mine, and now it works. He is ordering a new pedal.
      Check the foot pedal.
      Miller Dynasty700DX
      3 ea. Miller Dynasty350DX
      Miller Dynasty200DX
      ThermalArc 400 GTSW
      MillerMatic350P
      MillerMatic200 with spoolgun
      MKCobraMig260
      Lincoln SP-170T
      Linde UCC305 (sold 2011)
      Hypertherm 1250
      Hypertherm 800
      PlasmaCam CNC cutter
      Fadal Toolroom CNC Mill
      SiberHegner CNC Mill
      2 ea. Bridgeport
      LeBlond 15" Lathe
      Haberle 18" Cold Saw
      Doringer 14" Cold Saw
        Wll, I'd guess that either your tig torch internal conduit is damaged, thats the reason for the HF only, or something is wonky with the footpedal like the last post
          Miller Syncrowave 351 help
          Tried it in stick, works fine
          I am going to check continuity in tig gun wire.
          Hope that is all it is.
            I know the 351 tends to be full featured... any chance there's a spot timer on there or something similar?
            Con Fuse!
            Miller Dynasty 350
            Millermatic 350P
            -Spoolmatic 30A
            Hypertherm PowerMax 1000G3
              Best to try a replacement torch as continuity will still be fine if the conduit has 1 strand left touching
                So it works on stick. Turn the machine off remote and to panel and see if you can scratch start an arc. Will be easier if you have lift start feature.
                If it works, you may have a funky pedal. Most times it is the wire cable frayed apart.
                Miller Dynasty700DX
                Miller Dynasty200DX
                ThermalArc 400 GTSW
                MillerMatic350P
                MKCobraMig260
                Lincoln SP-170T
                Hypertherm 1250
                Hypertherm 800
                2 ea. Bridgeport
                LeBlond 15" Lathe
                  He's still got on / off control and if in the control was damaged, the control would go back to the local controler, since he has next to zero output. I'd guess that his remote is ok. Besides I think he ran his stick on remote.
                    I think some of the Syncrowaves have the lift/arc feature. At least he could switch to it and weld. I still think the foot control has a bad potentiometer or broken cable wire.
                    My best reckoning is that I just went thru the same problem with a client.
                    It was the foot pedal. The old heavy duty sheet metal one. A new one from SSC controls is on the way for some $175.
                    Miller Dynasty700DX
                    Miller Dynasty200DX
                    ThermalArc 400 GTSW
                    MillerMatic350P
                    MKCobraMig260
                    Lincoln SP-170T
                    Hypertherm 1250
                    Hypertherm 800
                    2 ea. Bridgeport
                    LeBlond 15" Lathe
