If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
Would anyone know what kind of metal or application a 9018 B3L stick rod would be used to weld it with.?
(I found a couple buckets of them trashed at the refinery I work)
2.25% Chromium, 1% Molybdenum steel common in boiler work. Its a low hydrogen type rod.
T22, boiler tubes along with P22. 8018 b3L is used on 1 1/4 cr 1 moly. 2 1/4
chrome found through out the high energy piping, and superheat pendents with
associated headers and safety / relief valves.
9018 is specified by Manitowoc to be used in replacement of boom lacings in their cranes
Just because it calls for a 9018 doesn't mean it's calling for a 9018 B3L. Two different animals. Most stuff with chrome in it is meant for high service temps.
Dynasty 200DX "Blue Lightning"
Bernard 3500ss water-cooler
Rockwell vertical mill
Beverly Shear B-3
Beverly Shear JR
Home-made English wheel
Milwaukee Porta-band
" Sawz-all
Tennsmith 36" stomp shear
Fixer upper 1968 Redface Lincoln sa200
Powcon 300st
