Quick background: I bought a Diversion 165 this past spring so I could start making my own snowmachine parts. So far everything I've done has been aluminum and I'm fairly decent. I'm currently trying to weld up a 4130 chromoly steering post and would like some input on the proper tungsten and filler sizes.
I'm using 2% ceriated tungsten and ER70S2 filler, straight Argon at 20 CFH with a #6 cup(I use a 7 cup for the 3/32). I achieve nicer welds with 1/16 tungsten and filler but is this enough for the 1/4"? The 3/32 seems like it puts a lot of heat into the metal. I try to keep the tungsten as close to the base metal as possible to reduce heat input.
Here's a pic of what I'm welding up...
The main tube is .065 4130, the top and bottom pieces are 1/4" mild steel, and the middles pieces are all 1/8" mild steel. Everything has been cleaned extremely well(all mill scale removed) and acetoned before welding. I made one post but wasn't happy with the welds so I'm making another.
I've practiced a lot already, but I want to make sure I'm practicing with the correct size tungsten and filler.
Thanks for any input. I've done a ton of reading on the internet and already read through the Miller TIG manual and weldingtipsandtricks.com website, along with the multiple welding books I own, but haven't been able to find the info I need.
