Hello, I was hoping someone could give me some help on diagnosing an issue with my Oxy/Acet set up. It has worked fine up until recently. I am getting a seperation between the tip and flame when starting it up. Once I get the flame adjusted for cutting I am getting a constant popping sound. I am not sure what is causing this. I get it adjusted and it cuts fine, but I continue to get the popping sound. It's not loud just continuous about every 5-6 seconds.
Oxy/Acet problem
25-5 good
Adjust your mixture richer. Did you drop your tip, might not be sealing at the big nut. Look for a little flame around the nut.
Good Luck,
BobMillermatic 252 w/30A
Big Blue Air Pak
Ellis 3000 Band Saw
Trailblazer 302 Air Pak w/ Wireless Remote
8-RC
XMT 350 MPa w/S-74 MPa Plus
Millermatic 211
Passport Plus
Spectrum 625 X-TREME
Lincoln SA-200 Blue Tint Red Face '63
2-Lincoln SA-200 Red Face '68
SA-200 Black Face '59
SA-200 Green Lite '84
SA-200 Green Lite '80
SA-200 Red Face '69
SA-200 Red Face '66
SA-200 Green Lite '81
'70 Black Face Round Barrel
