Aluminum welding
I've got a millermatic 250 and I want to buy a 30a spoolgun and I'm wondering what gas should I use when I can afford to get this gun?
I've used helium in the past with a TIG on aluminium, but my experience with anything but mild steel is limited.
I have a millermatic 200. I only use my spoolgun for tacking anymore. Just too finicky for continuous welding. What I found was that I needed to clip the ball off the wire every time I started to weld or it would not start worth a darn. I clip the wire at a diagonal so the sharp end lit up faster.
I know that most people like 4043 better, but I have better luck with 5356, as it drives better and seems to arc up more consistantly.
Good Luck and have fun.
Aluminum welding
I have just bought a 252 millermatic welding machine and a used 30a spoolgun is there anything that i need to watch for while using this setup on aluminumTags: None
