When fabricating an assembly with two pieces of metal overlapping each other, what is the proper method of connecting them to reduce or eliminate rusting in the joint. To be specific, if I have two sections of, say 1/8"x6"x6" steel plate that overlap each other by 3"- and, say I want to weld the two parallel pieces together. And, let's say I want to stitch weld the seams, that is, not a continuous weld for the full length of the overlap. What steps do I take to make sure that, after painting the assembly, that I don't get rust coming out of the area of metal between the two plates. Should I paint the steel before welding(and wire brush off the area to be welded? Any insight would be appreciated.
Preventing rust in an overlap weld joint
spray some cold galvanizing on the area to be concealed
The paint dries quickly. Use a flap disk or wire brush to get rid of any spray in the weld zone if you want. Some of it is ruined by the welding heat, but at least you have protection in between the two sheets.
Originally posted by MTBob View PostWhen fabricating an assembly with two pieces of metal overlapping each other, what is the proper method of connecting them to reduce or eliminate rusting in the joint. To be specific, if I have two sections of, say 1/8"x6"x6" steel plate that overlap each other by 3"- and, say I want to weld the two parallel pieces together. And, let's say I want to stitch weld the seams, that is, not a continuous weld for the full length of the overlap. What steps do I take to make sure that, after painting the assembly, that I don't get rust coming out of the area of metal between the two plates. Should I paint the steel before welding(and wire brush off the area to be welded? Any insight would be appreciated.
I like Deafman's idea, also after it's painted you could silicone in between the welds.
.......... Norm
Lets keep in mind that anything applied to low alloy steel is just a delay on the rust setting in.
Even epoxy paint will break down over time and let in moisture.
Lets also keep this relative too. Epoxy paint is just about the best way to easily protect a surface from rust. It will take years for it to degrade but it will still degrade. And that is what needs to be addressed. You will never stop rust. You can only maintain the part/assembly. Depending on the application a new pain job every few years is the best thing, along with realizing that one paint job is not enough.Miller Syncrowave 200 W/Radiator 1A & water cooled torch
South bend lathe 10LX40
K.O. Lee surface grinder 6X18
Auto shades are for rookies
www.KLStottlemyer.com
If you can, get your part electroplated PRIOR to painting, that would be the best. A good cadmium (toxic) or zinc (non toxic) with a yellow chromate converstion coating (top coat, also known as "Type II yellow" in the industry) should suit you for a long long time.
I plate all of my parts that I weld PRIOR to painting. It just prolongs the rust problem that much longer.
Rhino-liner
In farming, they make these big gravity boxes for wagons. The boxes get lowered onto an angle iron frame that is built off of an under-carriage that used to be a big rig before hitting the junk yard. One guy sprayed Rhino-liner all around where the angle-iron contacts the sheet metal and 2 inches out on every side. I thought that was a good idea. Every springtime it would sweat between the sheet metal and the angle-iron and rust would spread out after a few years; and it would never be practical to weld solid on angle-iron to sheet metal. Also, in the spots where the angle iron connects to the under-carriage, this guy welded on fish plates to the frame where he intended to build off of... and then surrounded the whole joint with Rhino-liner.XMT 350 w/ S-75 DXA Feeder
and a Bernard 300 gun
Optima Pulsing Pendant
XR-W wire feeder + Coolmate 4
with an XR-W Edge Gun
Passport Plus w/Spool Gun
Regular Passport
Trailblazer 301G w/Freak Box &
S-32P volt sensing wire feeder
Spectrum 1000 Plasma
Spectrum 375 Xtreme Plasma
Regular Spectrum 375 Plasma
Victor H315FC torch & accessories
Victor 100FC torch & accessories
Meco torch & accessories by Kent White
Also, the auto companies used to have all those rust problems that arose out of overlapped joints that had been spot-welded or otherwise overlapped and had been painted over. Their solution was to run the line down into a submersion dunk tank of electroplated paint after the body was completed in the "Body-In-White" stage. Now, all components (even the frame...if applicable) is submerged in paint. Initially, they still neglected the frame. The bought under-carriage paint in bulk and got the cheapest stuff they could. All they cared about was to get the frame "black" because the customer wouldn't see it anyway.
I guess a guy with a weld shop could maintain a sealed tank of highly thinned rustoleum paint in which to submerge parts. Just add more paint and thinner every oncle in a while. It would have to be the size of a parts washer, have an aggitator pump of some kind, and have a gasketed lid so the thinner wouldn't evaporate away.XMT 350 w/ S-75 DXA Feeder
Regular Passport
What I have used a lot is a primer called 'Weld Thru Primer.'
It is loaded with zinc and you paint the surface of both sides of the plate joint then overlap the plates and weld it up. The primer dries quickly.
As the name implies, you can weld through this material and it protects the steel from then on.
pg
Dynasty 200 DX_set up on 3 phase
Coolmate 3
MM 251 w/ Spoolmatic 30A
HTP 625 Micro Cut Plasma Cutter
Victor O/A Rig
Bridgeport Mill_3 phase (w/ Acu-Rite 4 axis DRO)
10 inch South Bend Lathe_3 phase
Baldor Double Cup Tool Grinder_3 phase
Baldor 10 inch Buffer
Rockwell 12 inch Disc Sander
Cyclone 2ft X 3ft Bead Blast Cabinet
Quincy 325 2stg- Air Compressor_3 phase
Graymills Built-in Parts Washer
Rockwell/Delta Planer, HD Shaper, Uni-Saw etc.
Originally posted by seattle smitty View PostDon't spray silicone into the joint if there's any possibility that you will want to paint it later . . . .
............ Norm
Originally posted by nfinch86 View PostAs far as I know you can buy Paintable Silicone sealant .
............ Normmiller 225 bobcat
miller aead200le (with miller hf tig trailer mounted)
mm175, mm211, TA181i
mm252 w/30a spool gun
precision tig 225
hobart stickmate LX ac/dc
Speedglas 9100X & XX / Miller Digital Elite
hypertherm 380 & cutmaster 52
victor journeyman & super range
ridgid chop saw, kalamazoo band saw
steel max and evolution carbide saws
6 4.5" & a 20lb 9" rockwell grinders
case 580 backhoe (for what i can"t lift)
if first you don't succeed
trash the b#####d
Originally posted by piniongear View PostWhat I have used a lot is a primer called 'Weld Thru Primer.'
pg
That is a revelation.
ThanksNothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
