I'm hoping someone might share some tricks for welding sanitary 304 SS Tri-clamp-style short-weld ferrules to tubing without warping the ferrule. I've tried tightly clamping the ferrule to another or a cap to hold it, but the clamp gets in the way and it will still warp if it gets hot enough. I've tried making additional tack welds for the fit-up, but that doesn't seem to impact the flanged edge of the ferrule itself. Years ago, an experienced sanitary welder told me short weld ferrules were tough, but I don't remember what he said about how to avoid the problems. My guess is it all comes down to getting the weld accomplished with as little heat as possible. Until my technique improves or I can get access to a machine with more rapid pulsing, I'm not sure what else to do.
Tricks for TIG welding Tri-clamp short-weld ferrules?
I feel for ya.
Are you purging?Nothing welded, Nothing gained
Miller Dynasty700DX
3 ea. Miller Dynasty350DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MillerMatic200 with spoolgun
MKCobraMig260
Lincoln SP-170T
Linde UCC305 (sold 2011)
Hypertherm 1250
Hypertherm 800
PlasmaCam CNC cutter
Fadal Toolroom CNC Mill
SiberHegner CNC Mill
2 ea. Bridgeport
LeBlond 15" Lathe
Haberle 18" Cold Saw
Doringer 14" Cold Saw
Originally posted by shovelon View Post
I feel for ya.
Are you purging?
I have made expanding mandrels for repair work on alum bike frames.
MTBR frame forum members have made them out of brass. I think Paragon machine Works (cycle products) markets something similar.http://www.paragonmachineworks.com/storename/paragonmachineworks/ViewDept-261334.aspx
Perhaps a copper cylinder with tapered threaded fittings to expand, and the flange would indeed do the trick.Nothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
Originally posted by shovelon View PostI have made expanding mandrels for repair work on alum bike frames.
The upper one holds it straight and is a blocking shoe for alum, the copper one holds straight and acts like a heat sink for steel.Nothing welded, Nothing gained
Miller Dynasty700DX
Miller Dynasty200DX
ThermalArc 400 GTSW
MillerMatic350P
MKCobraMig260
Lincoln SP-170T
Hypertherm 1250
Hypertherm 800
2 ea. Bridgeport
LeBlond 15" Lathe
