Settings for Miller Regency 200 welding 6061 T6511 1/4 sq. tube.
    Originally posted by ryanjones2150 View Post
    I have a 30a, so that’s probably the case for me. You couldn’t plug the 30a into the regency, it has the four pin plug....I think.
    That makes sense.
    I ran out of time and didn't get to test the Spoolmatic 3 today, but did test both of my 22A wire feeders on it and the combo is very nice! I had already figured out what the voltage should be on each tap and used a ballpark guess wire speed on the 22A and was pretty close from the start. I will say it sure seems like it's got more power than the rating would indicate and I didn't crank it all the way up. I also backed it way down and was able to lay down a very pretty small bead. It's not like I really need another MIG welder, but I think this is going to stick around a while as a backup or for those times when I have the push/pull on the 350P and don't want to take it off.
    Next up aluminum....I'm going to try writing down settings (if they work).
      Well, if you decide to let it go, I’d be a buyer for it!
