About 2 years ago I installed a 125 amp sub panel to my out building (per code and inspected) Right now it only has one circuit on it, feeding 4 receptacles. The first receptacle in the line was a GFI. The GFI recently went out, I thought I had a bad receptacle, so I replaced it. Turns out it won't reset either
. The cable to the sub panel is all in conduit and the one circuit is also in conduit. I disconnected all downstream load circuits from the receptacle, but no luck there. How do I go about tracking down a ground fault, exactly what's the mechanics of the problem, what am I looking for?
