Anybody have the tables, for a center concentrated load, for H-beams??? Interested in W8 x 18, also W6 x 15 and W6 X 16. 8' span, supported both ends.
Load ratings for H beams
Yeah, figured that out by now. So an 8 x 5 1/4 x 17 beam, according to your table, is good for 24,000 pounds distributed load, 12,000 pounds center load. Correct???Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
Originally posted by NMWelds View Post[ATTACH]24641[/ATTACH]See if this helps. It's from AISC's Manual of Steel Construction, Allowable Stress Design. The book is from 1989 so use the information at your own risk.
Do you divide those numbers in half for center point loaded beams? And do you know the safety factor of that book?Caution!
Sonora, thanks for the welcome! I was actually inactive long enough for my pw to expire, so I guess I'm born again
You would have to divide by 2 for your allowable concentrated load at center.
Total equivalent uniform load = 2*concentrated load at center.
I don't know the safety factor for this book, been too many years since I had to worry about this stuff.
Sorry for my first post back to be only a partial answer.
NMWelds, thanks for chiming in, that's exactly what I was looking for.
Thanks also, for including your source,,,, turns out, that is kinda an expensive book, but possibly well worth it in the future.Obviously, I'm just a hack-artist, you shouldn't be listening to anything I say .....
I have a copy of “Manual of Steel Construction” somewhere but can't find it!
I was comparing the chart you posted to my Ryerson book, there is a slight difference in the numbers, must be the safety factor.Caution!
JS,
No problem sharing what I got.
Don't go trying to design anything too complex from MY info. There are a LOT of factors that go into designing a beam "properly". Is it laterally supported? Are the loads static? Is wind a factor? Safety factor? etc. etc.
Now get back to work.
