Pictures from school
  • Pictures from school
    Started my B-Level at UFV (in Chilliwack, British Columbia) with Jim Carson a little while ago and am currently in my third week of the program. I've been taking some pictures as I go and thought I'd post them up for those of you who'd like to take a gander/ comment.
    I'm in the half of the class that started on GTAW, so obviously that's what the pictures will be of for the next little while.
    Start out with some fillets on mild steel.
    -3/32" 2% Thoriated tungsten
    -3/32 Filler, 1/16 on the inside corner 3F
    Owner of Burnt Beard Fabrication & Welding Ltd.
    BigBlue 500D
    Millermatic 211
    4' Box and Pan Break
    IR compressor
    More fillets. 3F.
    BigBlue 500D
    Millermatic 211
    IR compressor
      Here's a few of my 1G open root. Bent it today and it passed with no defects what so ever. The apperance isn't quite where I'd like it to be but I'm trying to make time and keep ahead.
      -1/8" 2% Thoriated
      -1/8" Filler
      -#8 Cup Aproximately 18cfh
      No landing, root opening was just enough to lay the filler in without it falling through. Machine set to 115 amps but didn't have the pedal all the way down. 2nd Pass, laid filler in and weaved over top. Machine set at 130 amps, used most of it. 3rd and Cap passes, Laid two filler rods in and weaved over top. Machine set at 160 amps, used most of the pedal travel. All passes were free hand.
      Note that the second picture is of the second pass, not the root.
      BigBlue 500D
      Millermatic 211
      IR compressor
        Dang nice work Shorerider16.
        If you lived in the Los Angeles area, I would offer you a job.
        Miller Dynasty700DX
        3 ea. Miller Dynasty350DX
        Miller Dynasty200DX
        ThermalArc 400 GTSW
        MillerMatic350P
        MillerMatic200 with spoolgun
        MKCobraMig260
        Lincoln SP-170T
        Linde UCC305 (sold 2011)
        Hypertherm 1250
        Hypertherm 800
        PlasmaCam CNC cutter
        Fadal Toolroom CNC Mill
        SiberHegner CNC Mill
        2 ea. Bridgeport
        LeBlond 15" Lathe
        Haberle 18" Cold Saw
        Doringer 14" Cold Saw
          Tig
          Nice start.
          Lose the foot pedal. Learn the basics scratch start with no remote teaches you to control the puddle with travel speed and concentrate on the puddle. In the real world there is usually is no room for a foot pedal (Maybe a helper with a remote that you can yell up 5 down 5). Unless you get a job at a bench welding widgets for 8 hrs a day then you will get a foot pedal but not likely right out of school.
          Some of that looks like you were walking the cup. Learn freehand first.
          Practice free hand with both hands all positions. There are enough one armed welders out there do yourself a favor learn to TIG with torch in either hand
          Keep your stringers to a width of between 3 & 5 times filler MAX.
          Bobcat 225
          The rest is bright RED "Tig & GMAW"
          Just got a new Hypertherm 30
            Originally posted by Hillbilly69 View Post
            Nice start.
            Foot pedal is how they want us doing it, although for the most part I'll set so I can put the hammer down the whole time or end up staying at the same amperage. I know that outside of the school booth there arent' too many joints perfectly positioned with a foot pedal.
            With the exception of the 3f inside corner, all the welds were free hand. (I actually find it easier, although that may be because I have little practice walking it?)
            I know where your coming from with the monster weave, but that's still how were taught up here in Canada, or at least BC. From what I've heard the U.S. leans towards stringers, in all positions. Although it looks like that may be changing as the curriculum and what not is revised.
            I've done a little practice with the wrong hand and it actually wasn't that bad, as long as I haven't had too much coffee
            Thanks for the advice, it's much appreciated. I'll have some more photo's soon I hope, should be finished the groove welds and moving on to stainless by next week.
            BigBlue 500D
            Millermatic 211
            IR compressor
              Well, i've got a few more for you guys.
              First two are the bent coupons from my 1G test. Third is the face bends from my 2G and the fourth are the root bends from my 2G. The all passed with no deffects, which was deffinately nice.
              BigBlue 500D
              Millermatic 211
              IR compressor
                Some pictures of the 2G test.
                Essentially the same set up as the 1G.
                BigBlue 500D
                Millermatic 211
                IR compressor
                  I was in a hurry to finish this one off so I didn't get any pictures of the cap. The cap was done with three stringers however, as opposed to the weave technique used on most of the other positions and passes.
                  BigBlue 500D
                  Millermatic 211
                  IR compressor
                    Here are some pictures practice in on 3G. Currently working on the test and hopefully it will be bent sucsesfully tommorow.
                    Once again a very similar set up to the previous two positions. All passes were done free hand, no cup walking although I have been practicing that as well. The rod in the last picture is a 5/32" just for size reference.
                    BigBlue 500D
                    Millermatic 211
                    IR compressor
                      Aint it nice when everything goes right?
                      Doing any aluminum yet?
                      Miller Dynasty700DX
                      Miller Dynasty200DX
                      ThermalArc 400 GTSW
                      MillerMatic350P
                      MKCobraMig260
                      Lincoln SP-170T
                      Hypertherm 1250
                      Hypertherm 800
                      2 ea. Bridgeport
                      LeBlond 15" Lathe
                        Sure is when everything goes right. Not at school yet, but I've played with a little bit on my own in the past. Stainless is up next.
                        BigBlue 500D
                        Millermatic 211
                        IR compressor
                          Very nice welding, How was your pipe looking? or you haven't done it yet. And the SMAW, did you take any pics of those?
                            You will love SS compare to steel, I did, myself anyway, good job.
                              Keep it up Shorerider, and when you're done don't forget to register and do the Red Seal. Are you planning to get your A ticket as well?
                              Jonny
                              Dynasty 300DX
                              Esab PCM 1000
