I may have a chance to get a xmt304 for CHEAP, I was thinking about getting a suitcase wire feeder to go with it. Would this be a better setup than the mm 251? I was looking at the xmt and it should have the pulser, and I would have the higher steel tig capacity than I have with my dynasty 200dx
xmt304 with wirefeeder or keep my mm251
Originally posted by jake View PostI may have a chance to get a xmt304 for CHEAP, I was thinking about getting a suitcase wire feeder to go with it. Would this be a better setup than the mm 251? I was looking at the xmt and it should have the pulser, and I would have the higher steel tig capacity than I have with my dynasty 200dx
The XMT does indeed have a lot more flexibility than an MM 250 style machine. In order to pulse with it, you will need an Optima 304 pulsing unit tho.
The XMT also stick welds quite nicely as well. DC TIG on Lift Arc setting is good too.
I would go for the XMT. I have had one for years & have never actually owned a larger all in one wire machine. If you don't end up getting a feeder right away, I do have several Miller 60 Series 2 & 4 drive roll units available fully reconditioned with a 90 day warranty.
Good luck on it.So you're telling me...You're not nostalgic? Then, give me another word for it......
It is supposed to be like $400
they have two of the millers and like 6 similar lincoln machines
I will keep you in mind in the wire feeder, I am wanting to get a portable wire feeder but I may run what I can get for now. I would like to have this setup completely before selling the 251 just to make sure everything is good to go.DYNASTY 200DX
SPECTRUM 625
MM 251
BWE
For $400, I would be buying every single one they had. Keep one, sell the other for about a grand+ & get yours for free.
Better go & grab them. Someone else most certainly will at that price if you don't.
As long as they work of course. If they're junk, prolly not worth the headaches, even as cheap as they are.
Let me know how you come out.So you're telling me...You're not nostalgic? Then, give me another word for it......
Oh, and do some side by side testing of the power supplies. If the Lincoln unit is an 'advanced process' one, it should have pulse over pulse MIG built in (I think). Takes your nice and smooth MIG weld and adds evenly spaced stack of triangles shaped ripplesCon Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Hypertherm PowerMax 1000G3
Jake,
At those prices, I'd make dang sure you're getting the XMT304 CC/CV.
I guess I still come from the school of thought that says, "If the deal looks too good to be true, it probably is".Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Night and day difference there. In many cases that's what happens. A dude "scores" a great deal on one only to find out it's a CC only machine or high voltage only unit. I bailed a friend out of a deal where he got a CC only unit & didn't realize it until he was about to close the deal. Worked out good for me tho.
He bought a Maxtron 450 from me
Even for $400, unless an XMT 300 was like new, and had accessories included, I would let it pass. They were good machine for their time, but if they happen to have issues, you'll be singing the blues when you get a load of what it costs to fix one.
Some repair shops (including my limited capacity operation) won't even touch them. Someone in the hunt for an older inverter would be best looking at a Maxtron 450 since there were so many of them made for the industrial robotic welding market & often times, used parts can be had for cheap if you know where to look.
No doubt on checking it all out & being sure of what you're getting.Last edited by 7A749; 09-02-2010, 01:37 PM.So you're telling me...You're not nostalgic? Then, give me another word for it......
The bidding may go up to high on them and push them out of what I will pay, but it was some tools at work a contractor left behind that had to be de contaminated so they just left them. (real common in nuke industry) it is a 304 cc/cv, non of the lincoln welders had the pulser these machines were 2005's and have been sitting in storage since 2006 I do need to double check that it is not the 480only machine, I thought I remember they both say autoline on them. I would try to get both but the extra cash is not there right now. i am going to try though...the machines were mostly used for tig but some steel stick also.
I would like to get a pulser for it I have seen some welding on offroad stuff that I thought was done with a pulser, I have not been able to replicate the clean looking welds like that I can make a nice stringer bead but nothing like that with a real nice even spaced ripple.DYNASTY 200DX
SPECTRUM 625
MM 251
BWE
Originally posted by jake View Post... it was some tools at work a contractor left behind that had to be de contaminated so they just left them. (real common in nuke industry)...
Good luck.Con Fuse!
Miller Dynasty 350
Millermatic 350P
-Spoolmatic 30A
Well, if they have been bombarded with nuclear radiation, at least you would be able to find them in the dark.
Sorry, if you were to buy a feeder from me, it won't glow in the dark.So you're telling me...You're not nostalgic? Then, give me another word for it......
I've heard of some HOT welding machines being sold, but this takes things to a whole new level.
Jake,
Hate to be the one who breaks it to you, but it's the welder, not the machine that produces the bead you're looking for.
If you do end up with the XMT304 and are looking for an Optima Pulse Control for the 304, let me know. Got an extra one I bought for a buddy and he ended up getting rid of his XMT. Also got a clean 22A feeder if you're interested.Syncrowave 250 DX Tigrunner
Hobart HH187
Dialarc 250 AC/DC
the stuff is clean it would not be released if it was not. anything that goes in the reactor building is assumed contaminated until proven not just like this stuff. These may have been used in the outside staging area on clean equipment which was also considered an radiological controlled zone which also gets the same rules of assumed until proven not.DYNASTY 200DX
SPECTRUM 625
MM 251
BWE
