argon flow setting
  • argon flow setting
    When I went to school for tig welding my instructors had me use nothing but a gas lense. I am now in a situation where I need to use a standard body non gas lense. Will it require less cfh. I normally use around 12 to 15 cfh with the gas lense.
    Try it at 12 to 15, then kick it up a little. The gas lense is great for pulling your tungsten out more than normal, as well as the other benefits.
    A more needle like tungsten grind helps as well.
    Miller Dynasty700DX
    3 ea. Miller Dynasty350DX
    Miller Dynasty200DX
    ThermalArc 400 GTSW
    MillerMatic350P
    MillerMatic200 with spoolgun
    MKCobraMig260
    Lincoln SP-170T
    Linde UCC305 (sold 2011)
    Hypertherm 1250
    Hypertherm 800
    PlasmaCam CNC cutter
    Fadal Toolroom CNC Mill
    SiberHegner CNC Mill
    2 ea. Bridgeport
    LeBlond 15" Lathe
    Haberle 18" Cold Saw
    Doringer 14" Cold Saw
      We run ours at 30. Although I've seen a lot of posts that use 25.
        I run between 10-20 depending. For a non gas lens setup 15-20 will be fine. Much more and you can start to pull oxygen into the weld area.
        -Dan
        Owner
        DW Metalworks LLC
        Miller Trailblazer 302
        Miller 8RC Feeder
        Miller Passport Plus
        Miller Dynasty 200 DX W/Coolmate 1
        Hobart Handler 135
        Hypertherm PowerMAX 30
        Smith O/A Torch Set
        Plus more tools then my wife will ever know about....
          I would rethink 25 to 30 cfh. It takes a good amount of energy to produce your argon, and that means money. I just put a gas lense on my DX200 with air cooled torch and pulled my gas flow down to 10cfh. Otherwise I was running a 12 to 15 cfh with the standard collet body.
          At work, We run maximum 20 cfh on our 4 Dynasty 350s, welding 1" to 1" alum plate and bar, and #8 cups. Only do I run 25cfh on my CobraMig and MillerMatic 350P, both using alum wire.
          Miller Dynasty700DX
          Miller Dynasty200DX
          ThermalArc 400 GTSW
          MillerMatic350P
          MKCobraMig260
          Lincoln SP-170T
          Hypertherm 1250
          Hypertherm 800
          2 ea. Bridgeport
          LeBlond 15" Lathe
            1. Your "instructor" should have taught you how to determine your optimal flow rate. Don't know how you expect anyone else to tell you where to set your flow rate. Depends on the situation.
            2. Some posters must either work for the "gas supplier" or don't know jack about tig welding. Too much gas flow can be just as bad or worse than not enough.
            Depending on cup size, stickout, etc keep dropping your flow rate by about 2CFH until you start to see porosity in your "test bead". Bump it back up till the porosity disappears. That's your base. I normally run about 3-5CFH higher than my base.
            Using helium or a helium/argon mix is going to require a much higher flow rate due to the specific gravity (lighter than air) of the He.
            Syncrowave 250 DX Tigrunner
            Miller MM 251 w/Q300 & 30A SG
            Hobart HH187
            Dialarc 250 AC/DC
            Hypertherm PM 600 & 1250
            Wilton 7"x12" bandsaw
            More grinders than hands
              On TIG? That sounds like numbers usually reserved for MIG.
              For steel you can get away with less flow. With aluminum I dial in 5 cfh more.
              #7-#8 cup just about 15 for steel - maybe as high as 22 for aluminum.
              #5-#6 is more like 12 cfh for steel - right in the middle between 15-20 for aluminum.
              You can of course get even larger cups, just need to adjust flow accordingly. Miller does have on-line calculator that will give you a starting point to try.
              For non gas lens, use the same flow numbers, just remember to keep the tungsten stickout less than the nozzle diameter. #8 cup is 8/16ths of an inch or 1/2 inch. The less stickout the better.
              I try to use #7 cup for aluminum (I actually don't have a #8 right now) and #6 for steel. I have #4 and #5's available but they pretty much look brand spanking new.
              For each tungsten I have the normal, non gas lens collets and holders. I hardly ever use them. I have one use for them and it has to do with burning off zinc where I can't grind - the spatter would (and has) destroyed a gas lens (at least the outer screen).
              I had an older torch that you couldn't buy a lens for, replaced it pretty much as soon as I found out about gas lenses.
              Con Fuse!
              Miller Dynasty 350
              Millermatic 350P
              -Spoolmatic 30A
              Hypertherm PowerMax 1000G3
                Man, that was perfectly stated.
                Miller Dynasty700DX
                Miller Dynasty200DX
                ThermalArc 400 GTSW
                MillerMatic350P
                MKCobraMig260
                Lincoln SP-170T
                Hypertherm 1250
                Hypertherm 800
                2 ea. Bridgeport
                LeBlond 15" Lathe
                  Hey SUNDOWN I am still sort of a noob when it comes to tig welding. Sorry I wasn't born with a tig torch in my mouth. I wasn't looking for exact numbers just some info from people more experienced than me. Oh and just for you I did figure out my situation on my own. I have no control over what I am taught if I did i never would have gone to school. OH and by the way GO **** YOURSELF!! I get where you are coming from I just fel sorry for the other people who could benifit from your vast knowledge but you feel they are leeches of the system too lazy to figure it out for themselves. If it was easy everyone would do it. RIGHT?
                    I use about 5 cfh, gas lens, #4 cup, 14 to 33 amps average purged at about 2 cfh on the steel tuned exhaust pipes I make.
                    I used 10 to 12 cfh, 48 amps dc #6 cup gas lens, purged at 5 cfh when I was welding stainless tube in the dairies.
                    More gas flow isnt necessarily good as stated above.
                    I will try to post pics of the pipe fitting .062 steel coupler to .022 steel tube, butt welded and purged.
                    They are grey in color but 100% penetration, no porosity using the 5 cfh setting above.
                    mike sr
                      It's crybaby wanttobe "welders" who demand to be "spoon fed" information that make one question whether it's even worth trying to help.
                      No two flowmeters will read "exactly" the same.
                      Size cup, amps, tungsten size, material and filler, etc, etc. all affect the flow rate as well as the preflow and postflow.
                      A flowrate which works fine in a perfectly still area will generally be insufficient in an area with even slight breezes.
                      Pro mod you've got a lot to learn about welding and life in general. Might start by trying not to act like a punk.
                      Hobart HH187
                      Dialarc 250 AC/DC
                        Chill out man.
                        Sundown is right. Your tig instructor should have versed you in flow rates. But he backed it up with sage advice.
                        Miller Dynasty700DX
                        Miller Dynasty200DX
                        ThermalArc 400 GTSW
                        MillerMatic350P
                        MKCobraMig260
                        Lincoln SP-170T
                        Hypertherm 1250
                        Hypertherm 800
                        2 ea. Bridgeport
                        LeBlond 15" Lathe
                          Pro Mod Steve,
                          I got to say, that aside from having a smart mouth, with nothing to back it up, you are good for a really good laugh.
                          Just for S&G I went back and checked out a few of your posts to see what this "smart mouth" kid brings to the table.
                          I see in another post where you think you're worth $65/hr for your fantastic welding skills. LMAO. If you don't even know how to set your own flow rate, I seriously question how many other things you really don't know about welding.
                          I definitely can understand why you wouldn't post a location. If you did, I'm sure there are some "much more qualified guys" who'd be moving there to get in on some of that action.
                          Hobart HH187
                          Dialarc 250 AC/DC
                            That was really a good reply that is sure to get you more help in the future.
                            Griff
                              Just because we run our gas at 30 doesn't mean we don't know jack about tig welding. Why do we run it at 30? Because it's always been at 30. When I started at this shop 25 years ago the foreman said run em at 30. The welds have always come out great so it was never questioned. Now we do have a breeze running through our shop and we don't have gas lens cups so that might have something to do with it. Next chance I get I am going to do the test bead and change to cfh like you suggest and see what I come up with. Oh and your working for the gas supplier crack gave me a good chuckle.
