Idle frequency around the 43-48hz
Now as for engine, if its a 3600 rpm gasser use the 5-50, I don't care what model it is. I may never get to 50 wt as synthetic is temp sensitive, however at 100 deg F, its definately there. So since the engines are air and oil cooled, the oil also cools the engine Oil pumps have a dificuilt time pushing the standard 10-30 as it becomes basically hot water running out just as fast as its pumped in. The cooling becomes practically nil. Hech if I put 10-30 synthetic, in my big harley V-twin, The engine would bake itself pretty quickly and be sitting on the side of the road with overheat issues simular to what you guys are having.
We found years ago to use the 5-50 for all round protection and found Quaker to be the best hands down. Starts easy, and has the best protection. The engines simply doen't fail and run significantly cooler ar high temps.
The big diesels. even the high rev units, we use Guarol ECT (76 lubricants) 15-40 all rear round (stuff pours at -30C) zero engine problems
