Opinions Of The Miller 375 Plasma Cutter!!!
  • Opinions Of The Miller 375 Plasma Cutter!!!
    Title says it all!
    I like mine but if I were to buy again, I would get a bigger one next time since I been getting into thicker material.
    Synchrowave 180 Tigrunner
    Millermatic 251
    Trailblazer 302
    Spectrum 375
      I love mine, it's 2yrs. old & No problems at all !!!!!!!!!
      ........... Norm
        I have the Hypertherm Powermax 380, which is practicaly the same machine as the Spectrum 375 (non-xtreme model). I have been very happy with it. It works great within it's design capabilities. I've cut 1/2" with it easily, though not all that fast. The more air I give it, the better it cuts.
        Millermatic175
        MillermaticPassport/Q300
        HTP MIG200
        PowCon 300SM, MK Cobramatic
        DialarcHF, Radiator-1
        Hypertherm PowerMax 380
        Purox oxy/ace
        Jackson EQC
        -F350 CrewCab 4x4
        -LoadNGo utility bed
        -Bobcat 250NT
        -PassportPlus/Q300
        -XMT304/Optima/Spoolmatic15A
        -Suitcase8RC/Q400
        -Suitcase12RC/Q300
        -Smith oxy/propane
        -Jackson EQC
          Like mine but if I were to purchase another one I'd get one that has a torch you can disconnect. I think Thermal Dynamics has a unit similar in capacity to the 375 with disconnects for a few pennies less. Make sure you have a good water filter like a Motor Guard.
          Miller Syncrowave 200
          Homemade Water Cooler
          130XP MIG
          Spectrum 375
          60 year old Logan Lathe
          Select Machine and Tool Mill
            Plasma Cutting choice
            The 375 is a good machine for up to 3/8" mild steel. It is light and portable with a 120V or 230V input.
            For a hundred bucks or so upgrade to the 375 X-treme for a little more cutting speed.
            If you need to cut 1/2" plate or 5/8" plate upgrade to a 625 X-treme for a few hundred bucks.
            Scott
            Fab manager
            Welders360
              My next plasma will be the Hypertherm Powermax 45. It is still small and easily portable and has greater capacity than the Spectrum 625. It falls between the Spectrum 625 and 875 in both price and capacity and is about the same size as the 875. The Powermax 45 has a quick release torch, as does the Spectrum 875, I believe.
              Millermatic175
              HTP MIG200
              Purox oxy/ace
              Jackson EQC
              -F350 CrewCab 4x4
              -Bobcat 250NT
              -PassportPlus/Q300
              -Suitcase8RC/Q400
              -Suitcase12RC/Q300
              -Smith oxy/propane
              -Jackson EQC
