Drill bit for horseshoes
  • Drill bit for horseshoes
    I tried to drill a couple holes through a horseshoe but I broke a couple bits. Which type of bit wouldn't break on me?
    Standard Titanium, low speed drill press and cutting fluid.
      Cobalt Drill Bits !!!
      Cobalt by far are the Best I've ever used !!!!!!!!!
      ........... Norm
        I've drilled many horseshoes and have used both high speed steel bits and Ti coated ones with about equal success. The key is proper speed, pressure, and lube (I normally use cutting oil.)
          If you're drilling using the existing slotted nail holes I can see some potential for problems there .. Proceed slowly. Go very easy on the intitial feed with a larger bit and the feed for the entire distance with a small bit.
            Are we talking Horseshoes, as in the kind you throw in a game, or the kind a horse is shod with by a farrier?
            Miller Syncrowave 200
            Homemade Water Cooler
            130XP MIG
            Spectrum 375
            60 year old Logan Lathe
            Select Machine and Tool Mill
              No drilling required - Ask a blacksmith to show you how to "slit and drift" a hole.
              2007 Miller Dynasty 200 DX
              2005 Miller Passport 180
                Center cutting end mill might be a better option if it's an interrupted cut. Regular HSS should be fine.
                Syncrowave 250DX
                Invison 354MP
                XR Control and 30A
                Airco MED20 feeder
                Thermal Dynamics Cutmaster 81
                Smith O/A rig
                  this might sound crazy, but i was told by an ol;timer machinist that if you take your average cheapy drill bit, heat it up to red, then stick it in a potatoe, let it stay till cooled, will make it work wonders, some thing to do with the starch
                    My grandfather use to do the same thing but subsituding a drill pickle for the potatoe.
                      Potato Salad
                      You guys got the makings for a potato salad.
                      Bob
                      Millermatic 252 w/30A
                      Big Blue Air Pak
                      Ellis 3000 Band Saw
                      Trailblazer 302 Air Pak w/ Wireless Remote
                      8-RC
                      XMT 350 MPa w/S-74 MPa Plus
                      Millermatic 211
                      Passport Plus
                      Spectrum 625 X-TREME
                      Lincoln SA-200 Blue Tint Red Face '63
                      2-Lincoln SA-200 Red Face '68
                      SA-200 Black Face '59
                      SA-200 Green Lite '84
                      SA-200 Green Lite '80
                      SA-200 Red Face '69
                      SA-200 Red Face '66
                      SA-200 Green Lite '81
                      '70 Black Face Round Barrel
