Very expensive gas
  • fjk
    It's also good for making those Really ReallyReallyBIG EARTHSHATTERING KABOOMS!
  • pro70z28
    Originally posted by SundownIII View Post
    pro,
    No, that's methane that normally requires a "paper trail".
    I was thinkin' more like a "documentation" paper trail......
  • Railmen
    pro,
    Oh Man now that's FUNNY................
  • MR.57
    Hmm...interesting!
    https://www.fbo.gov/index?s=opportun...0566b&_cview=0
  • SundownIII
    pro,
  • pro70z28
    Sounds like something that would require permits or license to handle or some sort of paper trail.
  • kcstott
    It's for welding unobtainium!!!!
  • enlpck
    It's used for a variety of things. It is an isotope of hydrogen with a single neutron. Most hydrogen (much more than 99%) has no neutron in the nucleus-- only a proton. Deuterium is chemically the same (in most processes) as normal hydrogen, but can be identified by the greater weight of the atom, usually using a mass spectrometer. It's used in chemical synthesis, in nuclear research (the neutron changes the nuclear cross section dramatically), and in a number of other places.
    The place I have seen it was in making up tracers when I was working in the medical research lab. They would use deuterium in synthesizing a compound, and where the deuterium ended in a biological process that involved the compound, it told them about how the process worked. For example, if you replace a hydrogen at one end of a five-carbon linear hydrocarbon, like pentane, and the deuterium shows up in a bacterium growing exposed to it, you have evidence that the bacteria is taking hydrogens from the end of the molecule.
  • Showdog75
    You can gas weld with hydrogen and it seems similiar but super expensive. I didn't really think it was for welding just curious what folks would say it's for.
  • pro70z28
    I think Scotty uses it when the wrap drive runs out of dylithium crystals.
  • DamageInc537
    looks more like a bio-pharm type of gas, dunno about welding.
    http://encyclopedia.airliquide.com/e...a.asp?GasID=20
    if i read the whole sheet on it, i would have seen that its a flammable gas, so most likely NOT a shielding gas
  • Showdog75
    started a topic Very expensive gas
    Very expensive gas
    What is this welding gas used for ? http://http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=290443944258
