Dynasty 200DX W/Cooler Coolant Getting Dark ???
  • Dynasty 200DX W/Cooler Coolant Getting Dark ???
    Dynasty 200DX with cool mate 1 and WP20 torch
    6 hours 30min Time on the clock in 3 weeks.
    The coolant is getting light / mid tea colored what's the deal ?
    Mountain Metal
    Coolmate 1
    Miller Trailblazer 302 W/ Kohler
    Miller Suitcase 12VS Wire feeder
    Weldcraft 26 TIG Torch
    Miller 210
    Spoolmate 3035
    Thermal Dynamics 51 Plasma
    Jet 7x12 L Cooled Band Saw
    Delta Drill Press
    Dewalt Chop
    Add another tea bag. That one's done.
    Nothing to worry about. You've still got antifreeze protection.
    Syncrowave 250 DX Tigrunner
    Miller MM 251 w/Q300 & 30A SG
    Hobart HH187
    Dialarc 250 AC/DC
    Hypertherm PM 600 & 1250
    Wilton 7"x12" bandsaw
    More grinders than hands
      Just wandering what is causing that darking of the fluid, the levels full.
      Mountain Metal
      Coolmate 1
      Miller 210
      Spoolmate 3035
      Delta Drill Press
      Dewalt Chop
        What coolant did you use when you filled the coolmate?
        I've had mine almost 2 years, and the coolant has never changed color, with a similar amount of arc time...
        Benson's Mobile Welding & Fabrication
        www.bensonmobilewelding.com
        Serving the Dayton, Cincinnati, and Columbus, OH metropolitan areas
          you have a fab biz and you only logged 6.5 hrs on a unit in 2 yrs
          ''True genius,in many fields of human endeaver,is often revealed in elegant simplicity"
            Use coolant specifically for tig coolers and add only distilled water.
            2- XMT's 350 cc/cv
            1- Blue star 185
            1- BOBCAT 250
            1- TRAILBLAZER 302
            1- MILLER DVI
            2- PASSPORT PLUS
            1- DYNASTY 200 DX
            1- DYNASTY 280 DX
            1- MAXSTAR 150 STL
            1- HF-251 BOX
            1- S-74D
            1- S-75DXA
            2- 12-RC SUITCASES
            1- 8-VS SUITCASE
            2- 30 A SPOOLGUNS
              Did you flush the torch lines first?
              Dynasty 200 DX runner
              Sync 350 LX
              XMT 300 w/D74 and roughnecks
              Hobart 135
              ESAB PowerCut 875 plasma
                It's likely that he is not running a real LWS tig mix, and/or used tap water instead of distilled water.
                  No, 6 hours in the last 3 weeks.
                  And, the dynasty is not the only welder I own. I do more field welding off an engine drive than shop welding off of the dynasty.
                  And, even though I felt it was a rip-off, I went ahead and paid for the TIG-specific coolant from my local welding supplier. Seems like that's a better bet than gambling on automotive coolants...
                    6.5 Hours in 3 Weeks seems like a fair amout of use.
                    Yes it is the the coolant supplied with the new unit, Miller premixed coolant.
                    I did not notice the darker coloring until 5 hours or so. The torch and all parts are great, I really love the machine works Great.
                    Just tring to figure whats causing this. I will not run distilled water I am up in the high North only 90 frost free days a year.
                    Mountain Metal
                    Coolmate 1
                    Miller 210
                    Spoolmate 3035
                    Delta Drill Press
                    Dewalt Chop
                      Off hand, i would say that it is simply picking up particles from the torch, etc. Also, did you leave the cap off for a long time/ possible get dust in the coolant? Then maybe it could be mold of some kind?!?! just saying
                        any chance the radiator fins are plugged with fuzz?
                        allowing the coolant to over heat. If the coolant gets over 160F. The pump gets damaged. The veins in the pump swell and grind down putting carbon in the coolant. This can make it dark. One other reason for dark coolant. Is one of the rubber hoses breaking down and putting rubber into the coolant. Any chlorine in the coolant will cause rubber hoses to break down.
                        Glenn 300 amp stick
                        Millermatic 35
                        L-tec plasma
                          I would love to hear a tech chime in on this. I have the same issue with my Dynasty 200DX. I added the factory supplied fluid (I did not dilute it at all, per instruction). The fluid began turning yellow/orange on me within a day or two. The machine is brand new. I was only doing some very light torch work to begin with. I have not had any heat issues.
                          Out of concern I changed the fluid about a week ago. I did not flush the system so there was some immediate color change but the fluid is continuing to darken with use.
                          Oddly enough the container says "For use with TIG MIG PLASMA RESISTANCE INDUCTION" but it also states that it is not for use on a push/pull system... are they referring to AC? It has some comments about "may also be used in any system where aluminum is NOT in the coolant path." If I am welding aluminum it shouldn't have any affect here, right?
                            Mine Too
                            I bought a lightly used tig runner 200 DX and the guy told me it was ready for a coolant change. Unit was cared for and not abused and coolant was tan/brown upon pumping out. I did not flush the unit, so my new $25 a gallon factory coolant became tinged ASAP. Looks like some oxidation of whatever secret stuff is in the coolant.
                              I flushed mine with distilled water throughly yesterday. I did not like the look of that fluid, it seemed too viscus. I suspect someone at Miller choose the wrong supplier for their coolant and somebody will pay a hefty 'oopsy daisy fee' on this one. The fluid had some nasty material that I can only describe as pond scum that remained after the first flush. It took a more active cleansing of the reservoir tank to remove that stuff. Upon inspection of the metal filter, I found small remnants of this fleshy material. I ran over 5 gallons of distilled water thru the system before I felt confident that the majority of contaminants were removed. Keep in mind this unit is barely a month old.
