Chop Saw Brand
  • Chop Saw Brand
    Does anybody know what a good chop saw would be. I'm looking at getting one but not sure of what brand to go with.
    Are you looking for an abrasive chop saw or one of the newer dry cut types?
    Sometimes there's no second chances.
      We bought the Milwaukee dry cut saw late last year and have been very happy with it. The blade has almost 2K cuts and is still sharp. Recently we mounted the saw to a Delta miter saw/planer stand with a lazy Susan bearing under it so we can rotate the saw for cutting angles. The stand quickly folds into a hand truck configuration for moving with the saw still attached, for easy transport to the job site. Search my posts for pictures of the saw and stand.
      Charley
      ______________________________
      Miller MM252
      Miller Bobcat 225NT
      Miller DialArc HF & DIY Cooler
      2 Miller Digital Elite and 3 Fixed Shade Helmets
      2 O/A torch sets
      DeWalt 18 volt 1/2" Driver/Drill
      DeWalt 18 volt 6 1/2" Metal Saw
      DeWalt Porta Band & SWAG Offroad V3 Table
      Milwaukee 8" Dry Cut Saw
      Milwaukee 14" Dry Cut Chop Saw / Delta Stand
      Milwaukee 9" Grinder
      2 Milwaukee 4 1/2" Grinders
      Milwaukee Hole Hawg 1/2" Drill
      Wallace 5 Ton Gantry
      Too many hand tools
        I've had good results with the Milwaukee saw as well .
        Miller MM252 with Bernard Q300
        Hypertherm PM30
          I've got the Milwaukee (6190-20), too. I'm still on my first blade, and it's done a lot of cutting.
          I would never go back to an abrasive wheel.
          Jack Olsen
          The Garage(And its slideshow)
          The Car(And its slideshow)
            go with a good band saw
              ooooooo I want one...
              Bobcat 225NT
              Cutmaster 52
              Lincoln Weld-Pak 100 buzz box
              Caterpillar TH63
              '07 Kawasaki ZZR600
                Dewalt
                I have two Dewalts cold cut, one set at 90* and the other at 45*.
                They are made of stamped steel and the fence is not perfectly straight. I heard they fixed that, don't know for sure.
                The clamping system is poor, and when the iron comes loose it takes lots of teeth off the blade. About 100 each. They can be repaired, new carbide tips welded on and resharped.
                Look long and hard at the other brands first.
                On the bright side the Dewalt can cut 4" sch 40 PVC really nice and fast too.
                Good Luck
                Bob
                Millermatic 252 w/30A
                Big Blue Air Pak
                Ellis 3000 Band Saw
                Trailblazer 302 Air Pak w/ Wireless Remote
                8-RC
                XMT 350 MPa w/S-74 MPa Plus
                Millermatic 211
                Passport Plus
                Spectrum 625 X-TREME
                Lincoln SA-200 Blue Tint Red Face '63
                2-Lincoln SA-200 Red Face '68
                SA-200 Black Face '59
                SA-200 Green Lite '84
                SA-200 Green Lite '80
                SA-200 Red Face '69
                SA-200 Red Face '66
                SA-200 Green Lite '81
                '70 Black Face Round Barrel
                  the band saw is quiet and you can walk away from it
                  as its cutting it will turn off when its done
                    I've got the Evolution Raptor dry cut saw and I love it! The fence stays fairly square to the blade, and the clamp is not too bad for a saw in this price range. If you are really a stickler for quality of build and accuracy, then you will have to step up to a true liquid cooled cold saw. They cost about as much as a used Toyota. If you decide to go with an abrasive saw, I've used both the Dewalt and Milwaukee and they both performed well for saws in that class.
                      I have a Milwaukee 14" on the truck and a Makita 14" in the shop. Both are several years old and they've both been excellent chop saws.
                      Millermatic175
                      MillermaticPassport/Q300
                      HTP MIG200
                      PowCon 300SM, MK Cobramatic
                      DialarcHF, Radiator-1
                      Hypertherm PowerMax 380
                      Purox oxy/ace
                      Jackson EQC
                      -F350 CrewCab 4x4
                      -LoadNGo utility bed
                      -Bobcat 250NT
                      -PassportPlus/Q300
                      -XMT304/Optima/Spoolmatic15A
                      -Suitcase8RC/Q400
                      -Suitcase12RC/Q300
                      -Smith oxy/propane
                      -Jackson EQC
                        the dewalt dry cut is not even on the same page as the milwaukee. That milwaukee cuts straighter, faster, quieter, and cleaner that a milwaukee.
                        I like the band saw but for single cuts, or multiple small cuts I go with the chop saw.
                          So you think the Milwaukee is better than the Milwaukee? I was thinking about getting the Milwaukee but I guess I won't now. I will get the Milwaukee
                          then.
                          Nick
                          Miller 252 Mig
                          Miller Cricket XL
                          Millermatic 150 Mig
                          Miller Syncrowave 200 Tig
                          2-O/A outfits
                          Jet Lathe and Mill
                          Jet 7x12 horz/vert band saw
                          DeWalt Multi Cutter metal saw
                          Century 50 Amp Plasma Cutter
                          Propane Forge
                          60" X 60" router/plasma table
                            Don't you just love these forums?
                            OP, who's a new poster, comes on the board and asks for recommendations on brands of "chop saws". To me, that would indicate that he probably has a saw in mind in the $100-$200 range, since that's where most "chop saws" fall.
                            Several posters point out the difference in cut quality between the abrasive cut saws and the newer "dry cut" saws. Although a little of a reach from the OP's original question, I can easily see the comparison.
                            Then, along comes ol BC Iron works, who just last week blasted Miller for not providing him enough with enough bandwidth to "post his photos". His recommendation is that the OP go out and buy a $1,500+ bandsaw. Then posts photos bragging about "his saw". Then, on top of that, posts a second time showing "cuts" from his saw. BIG FREAKING DEAL. Nowhere do I remember the OP asking for recommendations for chop saw vs bandsaw.
                            Just seems unfortunate to me that Mr BC didn't avail himself of the opportunity to GTFO when shown the door in his previous posting. Bite the hand that feeds you, but come back for more right away.
                            Oh well. Just my .02.
                            Syncrowave 250 DX Tigrunner
                            Miller MM 251 w/Q300 & 30A SG
                            Hobart HH187
                            Dialarc 250 AC/DC
                            Hypertherm PM 600 & 1250
                            Wilton 7"x12" bandsaw
                            More grinders than hands
                              Good decision
                              Nice work pointing out that nothing is better than milwaukee except milwaukee.
                              I don't understand the dewalt fetish that a lot of people have. They are great at marketing, not so great at power tools imo.
                              Cold cut milwaukee is best.
                              Abrasive, the higher priced milwaukee is OK, so is the Makita.
