My Millermatic 251 wire feed will only start the roll drive at its lowest speed setting, if I continue to press the trigger it will speed up when I adjust the speed. If I try to start the drive at a higher speed I get a HL.P 005 error message. I removed the wire and drive roll, and checked the connections but still have the same problem.
This is my hobby welder and it has very little use (still on my first spool of wire). I took off the cover and it is very clean inside with no evidence of mice etc.
Could it be the motor or gear box? Should I disassemble clean and re-lube? Or is it the board?
