Great information here!!
I have a Bobcat 225G plus serial # KF881886 with 360 hours
Machine was stored outside for the infamous "year or two"
Using other post on the forum I got it running, generating, and welding but...
Testing it multiple times over several days, it always runs but may or may not weld. When it doesn't weld the 120 AC receptacle reads around 2.5 volts. The next start all may work fine, good arc and 120 volts. It either works on startup or doesn't. Letting it run doesn't seem to matter.
I've checked fuses F1 & F2, cleaned slip rings, brushes are free, cleaned and checked variable resistor on the bulkhead.
Any suggestions on what could be failing and how to test?
