Can anyone tell me why my 3/32 gas lens breaks in to at the neck down area? It's happened about four times using different amps from 120 to 180. Running an average of 15 cfm and only finger tighten the cup. Today had only welded about five minutes when it happened again. Hasn't happened with any other lens of smaller size. Just the 3/32. Tungston about 1/8 in. stickout using an air cooled torch. Could understand if had been welding max amps for a period of time but five mins with a dynasty 200 seems too soon. Ground was near weld area on clean surface. Know that can cause problems else where on stick welding or burning.
Gas lens breakage
This post makes no sense.
Are you talking about the gas lens or the cup?
Would probably help to let us know what cup size you're using. Could possibly be too small for a 3/32" tungsten, or it could be that you've gotten your hands on some defective cups.
I've run some #6 Weldcraft cups pretty hot with 3/32" tungsten, and haven't experienced that sort of problem.Syncrowave 250 DX Tigrunner
Miller MM 251 w/Q300 & 30A SG
Hobart HH187
Dialarc 250 AC/DC
Hypertherm PM 600 & 1250
Wilton 7"x12" bandsaw
More grinders than hands
Sounds like the cup is bottoming out on the gas lens. Maybe the teflon piece is missing or youre tightening it way too tight. It should be tightened to just contact the teflon then about 1/4 turn or just snug, if forced it can contact the end of the gas lens, then a heat and cool cycle can break the cup.
I have used them for years and it is unusual to break one other than overheating it or dropping it, or some sort of abuse.
As Sundown said, it may be defective cups as well.mike sr
gas lens breakage
Originally posted by abprt View PostSorry for the misconception but was talking about the cup and it is sized correctly for the 3/32 tungsten and not over tightened. Have seen bad tig torches so maybe it could be a bad batch of cups.
Originally posted by gnam View Postwere you welding aluminum? and there is no correctly sized cup for 3/32 you size the cup to your process for example I use a #5 on a root pass the I step up to a 6 or 8 for the fill and cap on pipe
Originally posted by abprt View PostWhen I decided to try gas lens, I orderd gas lens and cups for .040 / 1/16 / and 3/32 tugstens so each box and packages are marked according to size and that is how I select for correct size for the tungstens
-DanOwner
DW Metalworks LLC
Miller Trailblazer 302
Miller 8RC Feeder
Miller Passport Plus
Miller Dynasty 200 DX W/Coolmate 1
Hobart Handler 135
Hypertherm PowerMAX 30
Smith O/A Torch Set
Plus more tools then my wife will ever know about....
Your nozzle should be bottoming out on the teflon spacer. If it bottoms out on the threads on the gas lens you're sure to crack the nozzle when the metal gas lens expands from the heat. I've done this before when switching from regular collet body to a gas lens and forgot to put the correct teflon spacer in there. Just a few seconds of welding and it popped the end off.
Dynasty200DX w/coolmate1
MM210
MM Vintage
Lincoln AC225
Victor O/A, Smith AW1A
Cutmaster 81
IR 2475N7.5FP
Evolution Rage3
Jancy USA101
9" South Bend
AEAD-200LE
