350P Tractor welding
  • 350P Tractor welding
    A dude brought in a busted axle pivot bracket for me to make in my spare time. So I been fooling around with my mig a bit on STEEL!!!!!!
    He brought the steel in. As you can see it wouldn't take much to improve on what he had. It is on a big ole IH with a front loader. Made in the mid 60's I believe.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
    Nice job on that. That is the kind of stuff we deal with all the time.
    252 Miller Mig
    180 Synchrowave
    R - 45 Milling Machine
    Kingston 1100 Lathe
    Miller 2050 Plasma Cutter
      Just a few more cause I know you guys dig pics.
      It's been a few days back but I just wanted to post these. HMMM... let me see it was on pulse set on 247 WS with .045 Radnor wire ER70S6 and the rest of the settings I don't remember but it was nothing special.
      The piece was made out of 1/2" mild steel and the tube was 3 1/4" OD and 1 7/8" ID
      I still am amazed at the heat this machine cranks out. The chart said for 1/2" use 500 WS. That was so far out of my league it isn't funny. They musta meant 100% penetration with no prep.
      I would love to have a big job with a bunch of steel welding on heavy stuff for this thing. I could have a lot of fun getting used to running it instead of just guess and squirt.
      Miller WC-115-A
      Miller Spectrum 300
        isn't that MM350P just a GEM???...... Love Mine...........
          Looks nice!
          I find on mine I run just a bit more wire speed in pulse than the chart recommends. I'm using 98/2 gas though so that could be the difference. Looks like you got plenty of wet in at the lower setting.
          On something that thick, I would have run the verticals up.
          Millermatic175
          MillermaticPassport/Q300
          HTP MIG200
          PowCon 300SM, MK Cobramatic
          DialarcHF, Radiator-1
          Hypertherm PowerMax 380
          Purox oxy/ace
          Jackson EQC
          -F350 CrewCab 4x4
          -LoadNGo utility bed
          -Bobcat 250NT
          -PassportPlus/Q300
          -XMT304/Optima/Spoolmatic15A
          -Suitcase8RC/Q400
          -Suitcase12RC/Q300
          -Smith oxy/propane
          -Jackson EQC
            I did run them up when I laid the first pass inside the bevels I ground. On the cover pass I was getting such a big wet bead I set it up where it was going slightly uphill. I'm not much of a downhill guy on those big beads like I am when it comes to sheetmetal. It seems like it's gonna outrun me, so I stay with rotating the work if possible or uphill.
            I wish I would'a had about a dozen of these to make. Almost like repair...about the time you get everything set up your done.
            Miller WC-115-A
            Miller Spectrum 300
              350p
              Nice work Fusion! I've got a set of those saw horses, and I made a 2' x 4' "table" that rests on them. Take some 2" (1/8") angle, build a frame so the lips set on the horses. I then used some 2" (1/8") flat and made half of it a cutting grate, and put a small recessed plate on the other half. Put a handle on it, and like magic, a portable work bench.
              I used 1/8" material so it wouldn't be so heavy lugging it around.
              That 350P really puts out a nice weld.
              "Bonne journe'e mes amis"
                I know what ya mean about the big wet bead. I run the arc length way down to go out of position with it, or change to short circuit. Yeah uphill root and downhill cover works then. I shoulda figured you had that covered!
                I have a pair of those same saw horses too. Yep, lay a 1/4" plate on top and easy instant table.
                Millermatic175
                HTP MIG200
                Purox oxy/ace
                Jackson EQC
                -F350 CrewCab 4x4
                -Bobcat 250NT
                -PassportPlus/Q300
                -Suitcase8RC/Q400
                -Suitcase12RC/Q300
                -Smith oxy/propane
                -Jackson EQC
