Should I rebuild or not on Big 20 welder
  • Should I rebuild or not on Big 20 welder
    Hey Miller Guys
    I works with Salvage (rebuildable cars) Yard -my boss brought the Miller Big 20. The guy told him that that welder had bad or cracked head gasket of the engine. It won't run..I don't know what do with them?
    I should fix or have rebuild on the engine? How cost the engine rebuild kit would? Or Take it to Metal/Scrap yard?
    What is your suggestion?
    MillerMatic 211
    part2
    more pixes
    MillerMatic 211
      Nice pix dude.
      Welcome to the forum
      I think you should rebuild it if you can do the labor yourself. If not you may wanna put it on Craiglist.
      Miller 30-A Spoolgun
      Miller WC-115-A
      Miller Spectrum 300
        Can't really see it being the head gasket on an L head. Probably just siezed. Does it turn over at least?
          Can you post a picture of the faceplate? If it's what I'm thinking it is, they weren't much of a welder setting on the showroom floor.
          Caution!
            Is it worth it? It would make a big difference if it was a blown gasket vs a cracked head. Lots of running units around compared to putting a fresh engine in this one. If you need it thats a matter, or if you will run it long enough to pay or if you sold it tomorrow could you recoup the effort?
              I'd pull the head off see if it's a cracked head or just a blown head gasket....blown head gasket is a cheap fix....cracked head you could find out what other equipment uses that same engine and maybe find one in the junkyards. small skidsteers, aircompressors, ect. should be a tag on the engine...get the make and model and google it to find out what other things used that same engine.
              Bobcat225g plus
              8VS suitcase feeder
              Syncrowave SD180
              Miller CP250-TS S-52A Feeder
              Lincoln SP100 mig
              14x40 engine lathe
              bridgeport mill
              torch, plasma cutter, grinders, drills, and all that stuff
                Continental Red Seal F163.
                Way too easy to fix and the unit in way too good of shape to scrap. I say fix it.
                Syncrowave 180 SD
                *HF-251D-1
                *WC-1S & Spoolmatic 1
                PakMaster 100XL
                Marquette "Star Jet" 21-110
                  That was pretty much my assessment as well. Even if the welder part was junk I would still keep what was left of the engine.
                  Miller WC-115-A
                  Miller Spectrum 300
                    Are we a compulsive junk collector?
                      I too would keep the engine, it would bolt right up to one of my SA 200s. Can't say I've run a Big 20, but have run a lot of Big 40's. Never was impressed with the arc! Back when wire feeds were just coming out, a lot of outfits had Big 40s they put out too much OCV, so we had to back the engine rpm down so the wire would feed.
                      Caution!
                        OMG....look who's talking!
                        I believe WE would be correct
                        Miller WC-115-A
                        Miller Spectrum 300
                          I turned it over. Pretty hard turn...
                          Here>>
                          T
                          Yes I found thru google. It is Continental 4 clyinders- come from aircraft something?
                          Where I can get the replace the parts like new gaskets,new bearings for crankshaft and cam.
                          MillerMatic 211
                            It is Big 20 Constant Current DC Arc Welding Generator
                            If I decide to rebuild on engine, can add the Tig?
                            MillerMatic 211
                              Remove the plugs, add a couple oz's of WD-40 to each cylinder. Re-install the plugs. Let it sit over night or for a couple of days. If it turns over now, it should fire up
