I don't no anyone around here with a Diversion 165 so I thought I'd throw this out there if anyone has the time/interest/scrap. Could someone with a 165 try some welds for me. I'd be interested if the Diversion can weld:
1/2" round bar to 1/2" round bar, in a "T" butt joint. Ends just cut square, nothing fitted.
1/4" round bar the 1/2" round bar , same joint as above, same prep.
1/8" flat bar to the side of a piece of 1/2" round bar. same as above joint and prep.
I'd like to see if all of the above welds are possible on both Alum. and Steel. I'm not looking for shipyard strength. Just enough to hold it together well, like for a sculpture. I'm thinking, in my inexperienced in TIG mind, that the steel will be possible. But I'm wondering if the 1/2" Alum. is going to be sucking too much heat away. Not looking to weld lots of inches at a time, just around the diameter of the 1/2" round to the side of another 1/2" round, for example.
I can theorize all I want, but if someone could put the pedal to the metal( har har har) I'd be very grateful. You be answering the big questions for me in deciding on buying one. Just don't want to get it home and find out" Oh $hit"
Maybe some fellow artists on here are doing exactly this kind of "not the usual" kind of welding. I hope my description makes sense. If not , I can always do a doodle for you.
Super big thanks to all that can help.
I know a Sync 200 would be a good choice but for the $ difference I can get other tools I need!!!!
Regards,
Bert
Regards,
Bert
