Syncrowave 300
  • Syncrowave 300
    I am thinking about purchasing a used Syncrowave 300 and was wanting some input as to is it a good machine? I have a square-wave 175 Lincoln which I really like but want more power.
    Any one own one and what do you think of it?
    Thanks,
    David
    I've not run a 300 but have extensively used a sync 250 & they are great although they use lots of power. Make sure you have enough power to run it. A 250 needs 100 amps of 230v to run at capacity.
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
      All depends on what the cost is. They are a good, fully solid state TIG machine but never gained near the popularity the 250 did.
      It's a heavy machine, around 800# give or take & you'll need 100 amps+ to run it at full power.
      If you are getting it for under $1000 complete, in good shape & ready to work, good deal. If they want more....
      In this market, hold out for something better. Too many good deals out there to pay top tier for a used machine.
      IMHO of course.
      So you're telling me...You're not nostalgic? Then, give me another word for it......
        Thanks,
        David
        I have one of these welders. It is all the welder you will ever need(tig). From 5 amps to 300A it runs perfect. Has factory pulse and is great on aluminum. They are transformer machines, so they draw a lot of power, and it does weigh 700lbs or so.
          The synchrowaves are great machines, The new inverters like the Dynasty just makes it a little easier. But both machines basically do the same.
            Thanks for the replys guys. I have a chance to purchase it for 700 without any torch or leads. I have a nice water cooled torch and plenty of leads. Also I have 200 amps available to the garage.
            I would like the 300 amps possible.
            Thanks,
            David
