The other night I was running some autogenous lines down a few little coupons, just practicing getting the arc started, checking the affects of different amperage and the like (using 1/8" mild steel). I had something odd happen, and realized it's been part of what I've experienced all along and not even known it.
I did a few beads and they looked fine - just a clean line. I went to do another, without making any changes, and the next line was full of porosity and had that rusty, brown discoloration all around it. The rest of them wen that way. I ended up with one good line and about six or seven terrible ones, and all on the same piece of steel. I was running the gas at around 14. From what I've been told, that's plenty for the job. Tungsten was clean, and I even replaced it for good measure and had the same on/off results.
I have had this happen on several different pieces of steel a similar way. Sometimes I can do two dozen and they'll all look fine, then I go to do another, and all of the sudden they're terrible, and nothing seems to fix it. The arc can become very hard to start as well at this time.
I'm guessing these are symptoms of gas flow issues? I tightened up my bottle to welder connections, which didn't seem loose, but what the ****. I then used soapy water on the entire hose and fittings from the welder to the torch - no issues.
First off, I guess my question is, are these issues related to gas flow or gas quality? Second, any thoughts on narrowing down the issue would be great. This is sort of driving me nuts. I can make a bunch of good beads, then go to do some real work, and all of the sudden all I'm doing is creating craters full of holes.
Many thanks.
Many thanks.
