Whats wrong with these welds?
  • Whats wrong with these welds?
    Heres my first welds from the MM200 I just got working. The wire is crown ER70s-6 and the sheilding gas was 75/25. I had the gas at 15cfh then turned it up to 25 but it made no difference. The 2nd picture is a little better, I put on the regulator I got with the welder. The welds still look like garbage. I cleaned the metal with a grinder down to bare metal.
    This was the first weld, the pic in the first post was my 2nd weld after I changed regulators.
      I'm no expert but, it looks like you aren't getting enough shielding gas on the weld
        is there any gas in the C25 bottle? do you hear an audible click (gas solenoid opening) when you pull the trigger?
        Bobcat 225NT
        Cutmaster 52
        Lincoln Weld-Pak 100 buzz box
        Caterpillar TH63
        '07 Kawasaki ZZR600
          If you don't have a FLOW METER you are not measuring FLOW.
          If you have a dial type ORIFICE PRESSURE gauge, you are simply measuring pressure behind the regulator orifice. Your hose could be kinked and 100% blocked with absolutely no flow at all and it will still read wherever you set it before you pulled the trigger. If you put it to your ear to listen for a hiss, is that a 1CFH hiss or a 20 CFH hiss? Without a FLOW METER, you are just guessing.
          That said, it appears that is a combination of a few things. First, ineffective shielding (not specifically insufficient flow) which could be caused by a nozzle contaminated with spatter, or more likely, excessive contact-tip-to-work distance in combination with turbulent air.
          Second, excessive voltage.
          Third, failure to push the gun at the proper angle and travel speed.
          You can measure gas flow directly by connecting a rubber hose to the mig nozzle and discharging into a partially submerged, water-filled container of known volume and measure how many seconds it takes to displace the volume of water. Do the math to convert to CFH. Or you can buy a ball-type flow meter. Every shop needs one.
            Looks like you're also trying to weld on some extremely rusty, gritty, dirty material. Your work pieces need to be clean and free of contaminates.
            "Bonne journe'e mes amis"
              It has a hiss of gas and when I used the regulator that came with my machine it had the ball type meter. I had the ball type meter set at 20cfh.
              Unless there is a leak after the solenoid. The O rings were on the mig gun when I put it in. Ill have to check the hose from the solenoid valve to the mig gun.
              It was clean, I ground it down to clean bare metal. I did some welding on some paint and thats where the smoke mess came from.
                Give us all the parameters and we'd be better able to give you a good guess.
                Voltage:
                Wire speed:
                Wire size:
                Distance tip to work:
                South bend lathe 10LX40
                K.O. Lee surface grinder 6X18
                Auto shades are for rookies
                www.KLStottlemyer.com
                  is that bed railing?
                    My guess is turn up the gas, check the sticker on the bottle and be sure they gave you the correct gas, or maybe turn the shop fan off or at least in a different direction.
                      Maybe a little flash rust on the filler wire
                        what polarity are you using?
                        G
                          Do you have any parameter settings? Looks typical of too much amperage (WFS) for the voltage. Definitely have some "balance" problems between voltage and WFS. I know you just got this machine up and going, based on your other post. Just wondering if the nomenclature was still on the machine.
                            What is your stick out. You might have your gun tip a little too far from the workpiece. 25 flow is more then enough for gas.
                              I did alot more welds then this, they were all the same. I tried all different voltages, stickout, and different pieces of steel. It was all pretty much the same. The hiss of gas wasnt as loud as the tig welders I used to run in school. Since nothing seemed to have a effect on it Im wondering if it is a gas problem. I didnt have time today but Id like to check everything out from the solenoid valve to the mig gun. I should have cranked the gas all the way up and tried it.
