I work for the local fire department and we are looking into adding a plasma cutter to our heavy rescue rig. I'm looking at the 375 and the 625 but I'm not sure which one would work the best with our power supply. We have a 6000 watt generator that has 220. My question is that If I dial the 625 plasma cutter down can I use it with the generator and then If we get to incident and have a better power source we could use it to it max capacity then.
Plasma Cutter Info needed
Originally posted by KEENAVV View PostDo you have high volume 70 psi clean air?
Besides I think that they are using them for small cuts, like security bars not really needing to make long cuts.
I might be wrong?????????
Railmen2007 Trailblazer 302G
2004 Invision 354MP
1999 60 series feeder
2005 Maxstar 200DX
2007 CST280
1999 HF 251-1
older Hobart hefty wire feeder
Hyperthrem 600
Maxstar 150S(such a cute welder)
had and sold........
2003 XMT 304CC/CV
1947 Lincoln SA200G short hood
1963 Lincoln SA200G
1975 Lincoln SA200G(best machine ever had)
1970's Lincoln SAE400G
2 Maxstar's 200DX's
1 Maxstar 200SD
CST 280
2 CST 250
MM130
Railmen
Yes like railmen said we have a good supply of air with our SCBA bottles (Each bottle has 87 cu.ft.) and air compressor on the rig. The air compressor is 5.2cfm and is .8 shy of the needed capacity for the 625. As far as use of the unit, it is hard to say. We respond to all types of incidents and could be cutting anything from rebar in tight spaces to components of a collapsed structure.
Originally posted by RunownRockstar View PostYes like railmen said we have a good supply of air with our SCBA bottles (Each bottle has 87 cu.ft.) and air compressor on the rig. The air compressor is 5.2cfm and is .8 shy of the needed capacity for the 625. As far as use of the unit, it is hard to say. We respond to all types of incidents and could be cutting anything from rebar in tight spaces to components of a collapsed structure.
2004 Invision 354MP
2005 Maxstar 200DX
2007 CST280
1999 HF 251-1
Hyperthrem 600
2003 XMT 304CC/CV
1963 Lincoln SA200G
2 Maxstar's 200DX's
1 Maxstar 200SD
CST 280
2 CST 250
MM130
Railmen
Originally posted by cruizer View PostProbably not the best of ideas, being FIRE fighters and all. In order to cut something, you'll be spraying molten metal around.
Really better off thinking liquid nitrogen to break steel or hydraulic breaker jaws.
Thermite Cutting System
Might want to check out Thermadyne's ArcAir SLICE Fire and Rescue Cutting System. Search www.thermadyne.com and click on the ArcAir link and tab down to the SLICE system.
Dave"Bonne journe'e mes amis"
Runown,
Out of curiosity, what type of Rescue are you trying to equip? What level of training and responce are your members equiped to handle?
The generator, does this also power the lights, fans, vent systems, and saws also needed on the scene?
I think it may be harder to power such a tool than you think. I also wouldnt count on an on-scene power supply being readily available unless its another one of your rigs.
Just some food for thaught, Robbie
Originally posted by RunownRockstar View PostDo you know anybody with this product? It seems like it could be difficult to work with in smaller spaces. Looks like it works great if that's not an issue though.Sometimes there's no second chances.
Yes
The answer to your question is yes, the 625 will operate at reduced input power. With 6000 watts you might be able to cut 1/2" at 6"/min, as that's what the 375 does at 4000 watts or 27 amps out put.
At full out put (8000 watts) the 675 will sever 7/8" at 4"/MIN.
I just when through something similar with my Trailblazer 302 (9500 watts).
I will be able to run my 120amp plasma at 40 amps output, but that's it.
Good Luck
BobMillermatic 252 w/30A
Big Blue Air Pak
Ellis 3000 Band Saw
Trailblazer 302 Air Pak w/ Wireless Remote
8-RC
XMT 350 MPa w/S-74 MPa Plus
Millermatic 211
Passport Plus
Spectrum 625 X-TREME
Lincoln SA-200 Blue Tint Red Face '63
2-Lincoln SA-200 Red Face '68
SA-200 Black Face '59
SA-200 Green Lite '84
SA-200 Green Lite '80
SA-200 Red Face '69
SA-200 Red Face '66
SA-200 Green Lite '81
'70 Black Face Round Barrel
Originally posted by davedarragh View PostMight want to check out Thermadyne's ArcAir SLICE Fire and Rescue Cutting System. Search www.thermadyne.com and click on the ArcAir link and tab down to the SLICE system.
DaveOriginally posted by RunownRockstar View PostDo you know anybody with this product? It seems like it could be difficult to work with in smaller spaces. Looks like it works great if that's not an issue though.
I think every junk/scrapyard could use one of these.
The fact that it can work while being sprayed with water is nice. I wonder if they are simply saying if you was using a plasma cutter in the same situation you just might get your @$$ shocked into the future?
I am sure those rods are not cheap but neither is the time wasted saving a life.
Just the fact that this product is coming from a source that mfgs cutting torches and plasma cutters says a great deal to me.
At the very least I would have companies come and DEMO these machines to make an informed decision.
I believe Fire and Rescue needs every tool known to man when the time comes so good luck in deciding, and please keep us updated on you decision
P.S. Dave...how do you continually FIND all this stuff???? You and Brocoli could start a biz just making suggestions to companies on what the heck to do!!!Last edited by FusionKing; 06-16-2010, 06:32 AM. Reason: the normal thing....poorer than normal spelling
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
